It is currently Sun May 03, 2026 11:13 am
 Post subject: clean wiring
PostPosted: Tue Feb 03, 2009 8:26 pm
has anyone ran their wire through the buggy tubing. I want to do0 my whole buggy through the tubing is this even posible?
 Post subject: Re: clean wiring
PostPosted: Tue Feb 03, 2009 8:45 pm
I would stay away from that. There are more disavantages than there are advantages. Once you open the tubing you allow mud and water to get in no matter how well you try an seal it. Especialy if you use a pressure washer to ckean the buggy. Then it will rust and eventually weaken the frame from the inside out. Also you will not be ableto get thru any butt welded tube etc. Its also way more work than its worth. A simple way to get wiring from the front of the buggy to the back is thru a piece of thin wall conduit or PVC run down the middle. Then distribute from there. When I got my frame there was a few places were the wire goes thru the frame and one by one I have been welding them up. They are just a PITA!
PostPosted: Wed Feb 04, 2009 11:58 am
I've got the wiring for my taillights and headlights run through the tubes. It isn't hard to do and you want to make sure you seal the holes with silicone when you get the wires run in. I always pull the wire in and then force more wire into the tube for a service loop if I ever have to cut the wire for any reason. For the main loom going back to the engine from the dash box I always use control cable. It can be bought with 5,7, or 9 wires (probably more but thats all I've ever seen) and in different wire gauges. I use the 7 wire in 12 gauge, it is about the same diameter as a nickel and has a good thick outer coating that protects the inner wires. 8)
Aut Viam Invenium Aut Faciam!
PostPosted: Wed Feb 04, 2009 3:56 pm
thats what i did no some of mine. when you do it use your shop vac. and some sting to start it through the holes . then just work your way up to more and more wires.
PostPosted: Wed Feb 04, 2009 4:14 pm
That is pretty damn ingenious! Excellent idea! If your gonna run the wires through the tube.
PostPosted: Wed Feb 04, 2009 4:19 pm
if i would of realy thought ahead i could of opened up some of the tubes at the intersections before welding and made more of the wires disapear.
PostPosted: Fri Feb 06, 2009 10:29 am
I'm with Ody on this one ,Don't want no holes in my frame ,No matter how well you think you have it sealed it will leak water in .That thing will be like a chevy on a quiet night you can hear it rust
PostPosted: Fri Feb 06, 2009 10:37 am
My dad's old rail was wired like this. In one spot the tubing cracked and in another spot the wire shorted at the hole and when he tried to replace it he couldn't get it out and there was no more room for any more wires. When he finally rewired it he ran conduit and ran it through that.
PostPosted: Fri Feb 06, 2009 11:25 pm
I'm wiyh Ody too -- a guy i used to ride with had his wired that way too. His buggy is probably been around for about 17 years or so, and it seemed like every time we rode i welded his frame back up -- it was rusted bad from the inside out
PostPosted: Mon Feb 09, 2009 2:34 pm
Drilling holes in the frame will weaken the structure. not what i want to spend my time doing :( and then there is the rust thing :twisted: so no dont do it unless you like weakened rusty frames.
PostPosted: Thu Feb 12, 2009 11:16 am
Mine has been drilled since '76 and when I cut it apart to lengthen it there was no abnormal rust at all. Mine gets pressure washed, rode in the creek, and rode in the rain so there is plenty of opportunity for it to happen.
PostPosted: Thu Feb 12, 2009 2:20 pm
Like most things in life there are exceptions to the rules. You be special Kevin! :P :mrgreen:
PostPosted: Fri Feb 13, 2009 8:49 am
That was my nickname in school "Special K". :lol:
Got the package you sent. Thanks a bunch. 8)
PostPosted: Sun Feb 15, 2009 9:42 am
Well then "Getter Done"!
