It is currently Mon May 04, 2026 7:34 pm
 Post subject: my new boggers
PostPosted: Fri Feb 06, 2009 8:19 pm
16/35-15 boggers 2inches taller that a 35-14.50 bogger
 Post subject: Re: my new boggers
PostPosted: Sat Feb 07, 2009 12:10 am
Are you done cutting them or are you going to cut between the lugs?
PostPosted: Sat Feb 07, 2009 2:30 am
i cut the small lug out and i did cut them in between the lugs a little i will cut more later im ridin thids weekend its gonna be 70 degrees sunday
PostPosted: Sat Feb 07, 2009 8:15 am
Very nice job....I bet it is going to be a very muddy ride though :shock:
PostPosted: Sat Feb 07, 2009 11:06 am
we didnt really get any of that bad ice and snow last week it was all north of us
PostPosted: Sat Feb 07, 2009 10:39 pm
What did you use to cut the lugs out with?I might be doing a set for my Jeep and and definatly dont want to use a groove gun.
PostPosted: Sun Feb 08, 2009 2:56 am
take a 2 inch wood chisel,cut the plastic handle off weld u a good long handle about 1 1/2 foot and sharpen it really good and heat it in the middle of the chisel,dont heat the tip it will jus dull it,and dont get it to hot or it will catch on fire,i cut 9 lugs out on each time in between heating the chisel
PostPosted: Mon Feb 09, 2009 8:18 pm
lookin good
Are thy 35s
PostPosted: Mon Feb 09, 2009 9:45 pm
yea 16/35-15,we rode sunday at brutons,and they really work,broke a 5:42 r & p,so im gonna try a 5:86 now
PostPosted: Wed Mar 04, 2009 11:56 am
SAWZALL w/ wood blade cuts lugs like butter
Hello, this is America. Please press 1 for Spanish, press 2 for Chinese, press 3 for English...
PostPosted: Wed Mar 04, 2009 3:45 pm
yea if u put grind the teeth off and make them sharp like a knife,works really well to
PostPosted: Wed Mar 04, 2009 4:19 pm
I used a sawzall with course bimetal blade,,,worked great,,you can even cut some relief on the keeper lugs. :wink:
