It is currently Tue May 05, 2026 12:52 am
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Codename: Solo
PostPosted: Fri Feb 06, 2009 5:10 pm
We had the same problems with cyles buggy just cut them off and redo them. I have no idea what they jig the mounts with or if they even do. If you have some more problems list them on here i can probely help you out been there done that. By the way i bet one of your down bars go right into your header left side looking at it from the back.
DAREK
I want to die in my sleep like my grandpa. not screaming like the passengers in his car...
PostPosted: Fri Feb 06, 2009 5:53 pm
DAREK
Hey Darek I talked to Tim, he said it was mocked with a 6rib with a 5rib bellhousing. Now why this was done I have no freaking clue probably was ordered that way maybe. I haven't gotten to the motor yet but I will tonight after what you just informed me. Everything else seems to be going ok so far.
Kyle
"Lets go get stupid"
PostPosted: Fri Feb 06, 2009 5:56 pm
Hey Ody thats not a bad idea, I just really wanted to move the bottom one so I didn't have to have more stud sticking out of the motor. I think I am going to throw the motor up on there tonight see what we are working with.
Kyle
PostPosted: Sat Feb 07, 2009 7:30 am
that would make sense with the 5 rib housing the down bar would miss the header. they are very well built frames we are real happy with my sons i feel safe with him wanting to climb hills in it . i told him to get the predetor becouse he wants to climb bigger hills. not to mention they look bad a##.
DAREK
PostPosted: Sat Feb 07, 2009 10:51 am
It clears! Just barely we checked it last night
PostPosted: Mon Feb 09, 2009 2:31 am
Well I got most of it done tonight. It is basically complete on the fab side. I still need to do something about a drysump tank, I like the one Dave posted but it was kind of beatup, I am going to call Tim about the triangle one tomorrow. I also need to go up to Greg's one day and do all my welding. I still need to mount my trailing arms and get my shocks mounted up, put roof tabs in, and a backup light. I also after taking all your advice I cut the weld on the backside of the tranny mount then heated it up, sucked it tight with a bolt and then rewelded it. fits perfectly now. The pedals are made like that because the way the frame is it is hard to position your feet just right and get a good centered feel. I laid light guage plate to make a "floor" above the floor I also have something to brace my feet against. The battery box is directly behind my seat, I figured nice weight distro there being the battery is heavy. Heavy duty aluminum late model tierods with 3/4 heims. I drilled the spindles out to 5/8th's but it seemed a bit big for the spindle, do you think I should throw a different set on there and redrill them to 1/2? I can get 1/2 inserts for my heims at the race shop. I think thats it. Thanks for lookin, still thinking about powdercoat we will see.
PostPosted: Mon Feb 09, 2009 8:33 pm
Ok Solo That ain't plate steel you welding in the floor is it ? if it is DON'T DO IT ....Plate is weight ...Trust me you don't want no more than you got to have
Other than that ,That frame is cool .But ain't half the fun being able to take some unsuspecting sucker for a ride :shock: :lol: :lol: :lol: :lol:
We were at wind rock one time and a guy got hurt way back in the woods {on a 4 wheeler} and the parametics had to go in and get him 2am in the morning .By 2 every one that was not passed out yet was well on the way :shock: So all them guys hauled all them guys in :shock: :lol: :lol: Needless to say it was verry interesting
PostPosted: Mon Feb 09, 2009 10:53 pm
haha good story ya got from that one i bet. it is plate but its 14gauge which all in all prolly weighs 5 pounds. Mud on my boots is more than that haha plus it will keep the frontend down on those 94 degree climbs.
PostPosted: Mon Feb 09, 2009 11:48 pm
Kyle, Rock is right. If your gonna try to climb big stuff, ditch the plate. It might keep your front end down, but it'll also work against the buggy transferring and biting. 5 lbs. DOES make a difference, especially on the front end of a light buggy.
PostPosted: Tue Feb 10, 2009 12:29 am
There will be no try only make! haha man it is wayyyy to late for all that advise it is fully welded and smoothed already. done deal but i really doubt it is even 5 pounds. and i have to have it there is just no other options for my feet up there i am to damn tall i guess.
PostPosted: Tue Feb 10, 2009 1:39 am
Or you could just be a trail rider like me :mrgreen:
PostPosted: Tue Feb 10, 2009 8:34 am
:mrgreen: :lol: attaboy!
Buggy is comin along quickly and lookin good! Hope to see it in April at D&K!
yeah right 8) That werent no 'trail' you were on when you pulled an axle out of its cv!
PostPosted: Tue Feb 10, 2009 11:51 am
I am really really really hoping to be there for the hillclimb. I am just waiting to mount my arms and fab up the shock mounts. Going to order my dry sump tank from Tim today and hopefully I can tear down my motor this weekend to send off and get balanced. After it gets balanced its downhill from there just put it all together.
I am thinking about getting so new front arms also. What are most of your guys running +1? I have combo spindles now but I need to find me a set of arms just have no idea what sizes I need.
Kyle
PostPosted: Tue Feb 10, 2009 4:05 pm
4 over if you gona change from stock go all tha way 4 in over
and can I sell you a set just happend to have a set in stock here at R/R off road
PostPosted: Wed Feb 11, 2009 11:49 pm
get a step bit a drill a bunch of holes in that plate and stop adding waight to that thing and start shavin it off!
PostPosted: Thu Feb 12, 2009 10:50 pm
None of your pictures will load!! I even looked at your old build thread and none would load on that one. Was wanting to see more pics of the saturn rack your using.
Bryan
PostPosted: Thu Feb 12, 2009 11:03 pm
ahh we have major windstorms here that took out our business power today. Batteries lasted a few hours but still not power. the servers should be back on tomorrow and then the pictures will load.
60-70mph winds!
kyle
PostPosted: Fri Feb 13, 2009 11:34 am
There ya go Bryan all the servers are back up and running today. No more wind thank god.
I am using a offroad rack in this one I can't use the saturn rack its to big. The other build the saturn rack works perfectly. The double shear mounts I made on that one never failed.
PostPosted: Fri Feb 13, 2009 12:05 pm
Cool!! Thanks.
Which rack did you go with? The latest rage or a nicer one?
Bryan
PostPosted: Fri Feb 13, 2009 1:30 pm
Nicer lol, lots nice.
PostPosted: Fri Feb 13, 2009 3:20 pm
that was from me really under roy's name by accident :P
PostPosted: Mon Feb 16, 2009 6:15 pm
Few updates its getting really close. Got it fully welded yesterday and picked up my arms from Dean. Got all the belt tabs in and seat is all bolted down securely. Just waiting on my 930 cv kit to get here and can get shock mounts fabbed up. I STILL need to order my dry sump tank been being lazy on that one thats really the last fabbed piece I need to fit. Everything else is ready. By weekend maybe some paint or powder will fly.
PostPosted: Tue Feb 17, 2009 6:45 pm
Hill Climber
Did you finish welding the 2x2 tubes together? Looks like it in the pic.
Harry S. Truman
PostPosted: Tue Feb 17, 2009 7:43 pm
yep figgured better safe then sol.
PostPosted: Tue Feb 17, 2009 11:43 pm
What color are you going with? Orange and brown?
cron
