It is currently Sun May 03, 2026 2:46 pm
PostPosted: Thu Jan 29, 2009 10:41 pm
can anyone post some pics of there jig for there frount trailing arms....
and also do i have to get longer tie rods....
thanks
tanner
PostPosted: Sat Jan 31, 2009 4:52 pm
This was my first jig. It's 2-1/4" longer by 1" wider. A couple things to remember is on king/link the bottom arm is wider than the top arm. I think its about 5/16 or so, I can't remeber. Also, be sure you line everything up and measure well. When I made these arms, I tacked the top plate real well before removing it from the jig and tacked everything to gether and placed it back on the jig to make sure nothing moved. If I made any more arms I would Probly use a link pin in place of the bolt and use a piece of tubing with a bushing to hold the arm. (just like the front beam) When I made the jig I welded the bolt to the angle and bolted it to a stock arm and into the piece of angle on top. I made a line off the angle on the bolted end which was used a a reference line to make 2-1/4" x 1" . You may not need new tie rods but will use alot of adjustment.Hope this helps.
PostPosted: Sat Jan 31, 2009 5:06 pm
http://www.blindchickenracing.com/How_to/2x4FrontArms/2x4frontarms.htm
PostPosted: Sat Jan 31, 2009 6:01 pm
viewtopic.php?f=4&t=2261
PostPosted: Sat Jan 31, 2009 7:02 pm
MadMike wrote:
http://www.woodsbuggy.com/forum/phpBB2/viewtopic.php?f=4&t=2261
Well thats a hell a alot better than my turd addition.
PostPosted: Sat Jan 31, 2009 7:11 pm
I wouldn't agree. Did your jig get the job done? Then it's good enough. :wink:
PostPosted: Sat Jan 31, 2009 7:17 pm
thanks this helps alot
