It is currently Tue May 05, 2026 1:10 am
 Post subject: Through rods
PostPosted: Thu Jan 01, 2009 11:57 pm
I got laid off AGAIN just before Christmas so I am on a budget. I have some 10” fox air shocks I want to install in the front of my rail. Can I just make some through rods or do I need to spend the $50-$60 and buy them. I can handle that amount but if I don’t have to I don’t want to. I have some ½” solid round bar. Can I just thread the ends and put some fine thread top lock nuts and large washers on them? Or use a castle nut and pin them? Or should I look for some of the split lock nuts (not sure what they are called) like the ones that come with the kits? Any other suggestions please.
Thanks, Brad
Top lock nut
castle nut
 Post subject: Re: Through rods
PostPosted: Fri Jan 02, 2009 12:01 am
I have seen all thread in them. Did you get a set off ebay?
PostPosted: Fri Jan 02, 2009 12:21 am
Yeah. A year ago for 150 for the set but they are used (look like new)
PostPosted: Fri Jan 02, 2009 12:27 am
Brad my cd rails ,I used 1/2 in all thread
PostPosted: Fri Jan 02, 2009 12:54 am
What did you use to lock the nuts on? I heard a guy used some nylon lock nuts and they fell off and 1 arm slid out and broke his shock.
PostPosted: Fri Jan 02, 2009 1:07 am
once I got it adjusted I drilled it and put in a roll pin threw the nut an rod ground it smooth been working fine for years
o yea weld the nut on one side
PostPosted: Fri Jan 02, 2009 2:03 am
Just the cheap grade 2 threaded rod from lowes or home depot? Or should I look for grade 5 or 8?
PostPosted: Fri Jan 02, 2009 6:48 am
I got mine with my beam, but seem like they could be easily made. They got a nut and a jam nut. I was think about changing them out to a nut with pin..
PostPosted: Fri Jan 02, 2009 10:27 am
home depot cheep stuff there's not that much pressure on them
PostPosted: Fri Jan 02, 2009 4:41 pm
Thanks, Brad
Top lock nut
castle nut
The 1/2" round you have will work just fine. Its better than all thread because you can thread down to where the nut would stop and then you would not have sharp threads cutting on the ID of the arm hole. I used the crimp style nuts they sell for the trru and double nutted it for Insurance. The only issue is the tires can hit the ends when they are out that far so check them.
PostPosted: Fri Jan 02, 2009 5:21 pm
you can do what you want I don't see a piece of low grade all thred wearing out a hole in a chromoly arm but use what you want mine are about 8yrs old and the ones on my 4 seater are about 12 yrs old still doing good
Brad when your bushings wear you will need to adjust them
PostPosted: Fri Jan 02, 2009 5:52 pm
I used 1/2 inch smooth rod and threaded a short section on the end and then used some "clamp" nuts on them. The castle nut and cotters would be good to you dont want too much "stack up" with waser and jam nuts and stuff cuz it will stick out and bite your tires in tight turns under compression.
PostPosted: Fri Jan 02, 2009 8:34 pm
I know what you mean by stack up under pressure. Im clear now buy could see it rubbing in tight turns and speed in sticky dirt.. So what i was gonna do is you a clamp style jam nut with a chrome cap nut. Safety and looks good..
