It is currently Tue May 05, 2026 4:52 am
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Dec 29, 2008 1:52 pm
Hill Climber
wildwillie wrote:
ha dean i can get you a 64 2dr hard top that need to be redone?ill even haul it out to ya!
That would be nice. But with my new job I don't think I will be starting anything new for quite awhile.
Harry S. Truman
PostPosted: Mon Dec 29, 2008 9:47 pm
YOu got a 64 2 door hard top?? is it an SS.. What you want for it?? Got any pics.. I might be interested..
PostPosted: Tue Dec 30, 2008 4:38 pm
how bout a set of these for that v-tec mike :)
listen to the lope at the end.
"Lets go get stupid"
PostPosted: Tue Dec 30, 2008 7:55 pm
Those sound badass..
PostPosted: Tue Dec 30, 2008 9:28 pm
Thats why I'm looking for cams for suby, I want that sound!
PostPosted: Tue Dec 30, 2008 9:36 pm
Thats a B series honda engine. I thought they wouldnt work since they rotate counter clock wise?
PostPosted: Tue Dec 30, 2008 10:52 pm
you are correct. He is refering to the sound, lope of the cam.
PostPosted: Tue Dec 30, 2008 11:31 pm
flip ur trans upside down......
PostPosted: Thu Jan 01, 2009 12:08 am
I could be wrong but I believe only some Honda engines rotate the wrong way. I believe the newer ones spin the right way.
PostPosted: Thu Jan 01, 2009 1:12 am
Still a counter rotating engine, flipping the trans won't change that.
I think it's more like most honda motors are counter roatating. Ky-Bc has one bad ass Honda powered rail.
Go to Kennedy's web site and look at all the adaptors they make, if they make it, it'll work. If they don't make it there is a reason.
PostPosted: Thu Jan 01, 2009 4:58 am
Hill Climber
ky-bc's Honda spins the same way a VW does. Believe it, or not........
Harry S. Truman
PostPosted: Thu Jan 01, 2009 9:01 am
Don't get me wrong, I love my suby.
But if I were starting over, I would use a 3.1 chevy, mainly because the crank goes through the oil pan, thus more ground clearance.
The suby crank goes through the center of block, thus costing a bunch of ground clearance.
My pan is shortened 2" but with firestones mounted, still need more ground clearance.
PostPosted: Thu Jan 01, 2009 12:02 pm
The F and K series hondas rotate the right way. I know this has been discussed my upon many times but from what I hear if you flip the ring gear around it should work. Id be all over the s2000 motor if they wernt so damn expensive.
PostPosted: Thu Jan 01, 2009 12:08 pm
the biggest problem with fliping the ring gear is you cant do it on a bus trans. and when you flip then on the rest you are running the gears on the coast side . the weaker side.
PostPosted: Thu Jan 01, 2009 12:25 pm
Yeah trans brake often just running normal. I went with the toyota 3.0 v6 engine out of a 96 avalon. Lots of torque and fairly light for a v6 being all aluminum. Also only 2o inch from end to end.
PostPosted: Thu Jan 01, 2009 5:45 pm
corvair are reverse arent they??? an its been done back in the day that way
PostPosted: Thu Jan 01, 2009 7:12 pm
had corvairs most of my buggin days. they do turn backwards to the vw. but you can buy a rev. rotation cam for then and turn them the same way. helped the trans live alot longer.
PostPosted: Thu Jan 01, 2009 7:28 pm
ive heard of that just that ive seen a few with trans flippped but yea a cam would b a deff. plus
