It is currently Tue May 05, 2026 2:47 am
 Post subject: FRAME ?
PostPosted: Wed Dec 10, 2008 11:46 pm
Does anyone know how to tell what if a frame is set up for a KP or BJ front end?It is a brand new frame that is not put together. Thanks
 Post subject: Re: FRAME ?
PostPosted: Wed Dec 10, 2008 11:51 pm
mock up the side rails on the floor as they should be welded together then measure between the mounts. BJ is wider than a kingpin.
Aut Viam Invenium Aut Faciam!
PostPosted: Wed Dec 10, 2008 11:58 pm
the front clamps are higher on a bj the kingpin is closer and more narrower
PostPosted: Thu Dec 11, 2008 7:56 am
When you mock it up, the ball joint frame will measure, from upper clamp center to lower clamp center of about
5 7/8"
Link/pin would be about 5 1/4"
PostPosted: Fri Dec 12, 2008 1:39 am
Thanks for the quick responses
