It is currently Mon May 04, 2026 2:35 pm
PostPosted: Thu Nov 20, 2008 6:35 pm
36"iroks,they work awesome where we ride and they are light as a feather on bart beadlocks and if we go ride anywhere else i put my firestones on,they are also on beadlocks
PostPosted: Thu Nov 20, 2008 6:55 pm
i run cut 31-15.50/15 v treads tires not sure of brand but with a regular 5 wide rim with 4 bolt adapter the tires dig really nice but cant keep the bead on the rim anyone ever use those screws out of summit for your tires to hold the bead on if so how do they work good/bad not worth the 20 dollars
PostPosted: Thu Nov 20, 2008 7:10 pm
ive seen people use and and they work great
PostPosted: Thu Nov 20, 2008 7:18 pm
Frankenbuggy,,congrats on mod job,, I run different tires on different rides..I like the firestone 31x15.50x15 8ply mounted on 15x12 steel wheels the tires are cut by jellyjr and sharpened by me for hill climbs. I use babychains 17tooth over 17 tooth and stock 6 rib with my suby 140 hp . The babychains put the tires back about a foot from stock and out about 5 inches on each side ,,so I guess they would be called 5x12's. This combo works fine for me. I have the option to change ratios to 18 tooth over 17 tooth for my 35x10.5x15 boggers cut and sharpened on 15x10 steel wheels. This combo is like a 5 rib. 19 tooth over 16 tooth makes the 456 stock 6 rib like a 3 rib and might be good with a taller tire but I don't think I have enough power to turn the taller tire very well. I am anxious to upgrade to aluminum beadlock wheels some day. I also want to try a cut bogger in a 33 or 35 as wide as I can get once I change my engine . I like this forum and look forward to lots of ideas
PostPosted: Thu Nov 20, 2008 7:20 pm
31" ditch diggers, 6 plys. i want to get them cut, but money is an issue. haha
PostPosted: Thu Nov 20, 2008 7:56 pm
Of coarse, I run none other than the 31" Firestone flotation 23 degrees on mine. :mrgreen: 8 plies and are cut to the chords and the sidewalls cut too. HOOK LIKE CRAZY IN EVERY TYPE OF TERRAIN I'VE BEEN IN!!! Keep em sharpened and you cant stop em.
-Dakotah
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Thu Nov 20, 2008 9:27 pm
-Dakotah
Couldn't of said it better myself. My 'stones are mounted on Weld aluminum beadlocks.
PostPosted: Thu Nov 20, 2008 9:54 pm
I got something like this on front ,,,but in 6.70x15
http://cgi.ebay.com/IMPLEMENT-TRACTION- ... dZViewItem
PostPosted: Thu Nov 20, 2008 10:18 pm
yea sorry, forgot to put mine are on weld aluminum beadlock rims.
-Dakotah
-Dakotah/koko
PostPosted: Thu Nov 20, 2008 11:48 pm
Firestone 12.5L-15
Tony
PostPosted: Sat Nov 22, 2008 2:35 am
7.50 16 front goodyear single rib tractor tires on saco alm 16x4 rims
18.5x44 TSL on saco 12x15 alm rim on back
and on wet days
14.5x42 TSL with 56 5/8 bolts with 3 1/2 in rod couplers sticking out mounted on 12x15 saco alm rims. tires bolts and rims about 2200 bucks a set . my rubber tires are 1800 a set
i have 2 sets for my CD and my wife K-BABY has 2 sets
tires are killing me :shock:
PostPosted: Sat Nov 22, 2008 11:39 am
Hill Climber
I am in love with Boggers. They work for me VERY well. I run 35" x 14.5" on mine.
Harry S. Truman
PostPosted: Sat Nov 22, 2008 12:07 pm
Dean,,,I want to borrow your rear tires when I get my engine swapped :mrgreen:
PostPosted: Sat Nov 22, 2008 12:29 pm
Hill Climber
Sure. I will let anyone who wants to try them.
Harry S. Truman
PostPosted: Sat Nov 22, 2008 12:47 pm
I would love to re-try them again now that I have tuned in and learned to control it.
PostPosted: Sat Nov 22, 2008 3:44 pm
To Late Dave, You allready sold them! 8)
PostPosted: Sat Nov 22, 2008 7:35 pm
FB i will let you use mine
PostPosted: Sun Nov 23, 2008 2:03 am
they sure look good, too bad they don't climb as good....
Mike
Got Honda?
PostPosted: Sun Nov 23, 2008 11:55 am
Uh-oh, here we go! Mike is stirring things up again!
PostPosted: Sun Nov 23, 2008 8:07 pm
boggers
PostPosted: Mon Nov 24, 2008 10:58 am
I run a baby tire 29x12.50 my trans and lil motor cant take much now. But it runs like hell with the little tire need to adjust torsion to get back my clearance. Anybody wanna help I'm a torsion virgin. :mrgreen:
WHEN IN DOUBT DRINK ANOTHER BEER!!!!!!!!!!
PostPosted: Mon Nov 24, 2008 11:33 am
Hill Climber
Say what you will Mike. You'll get a chance to prove it here in about 5 days. I am guessing you tractors will be spinning out till you hit Vtech then the will spinout faster.
Harry S. Truman
PostPosted: Thu Nov 27, 2008 10:58 pm
just dont cut your spring plates if you have duals :roll: :oops:
PostPosted: Thu Nov 27, 2008 11:48 pm
Don't plan on it i've tried to keep the cuttin to a minimum on this project for now.
PostPosted: Sun Nov 30, 2008 8:31 pm
I know everyone loves the 23* but I was very happy with my goodyear 4ply's this weekend. Was wondering if anyone has tried the Mickey Thompson Baja Claws - Cut. Look bout like the boggers.
