It is currently Mon May 04, 2026 6:15 am
 Post subject: legenthening a frame
PostPosted: Sun Nov 09, 2008 10:42 pm
welllll....... since coldness and snow is here in ohio, it is time to start repairing/upgrading parts on the buggy. So me and my dad have decided to stretch his frame. it is 95" as it sits now, we are planning to put schedule 40 pipe inside the frame rails, and more 1 1/2" on the outside of the sechdule 40 pipe and weld it all up.
we lwgenthened my frame last winter from 87" wheelbase to 102" wheelbase. We are going to stretch his to about 100" or 101". the reason for the stretch is he has rolled 7 times in 4 years and it has been because he stands his buggy up too much. he never really had a problem with a 1641 and a 3 rib. but when he went to the 1915 and the 3 rib the rolls just kept coming. and its getting expensive, so ill post pic's when we start cutting his apart. and hopefully there will eb another section by me posting pic's of me switching into a 1 seater, if everything works out.
if you have any comments or ideas...... they are welcomed with open arms! :D lol.
dave
 Post subject: Re: legenthening a frame
PostPosted: Sun Nov 09, 2008 11:45 pm
I have faith in you guys! You did a nice job on the one you got from me a couple of years ago.
PostPosted: Mon Nov 10, 2008 5:45 pm
to me a 103" wheelbase is perfect thats what mine is
PostPosted: Tue Nov 11, 2008 11:46 pm
thanks! We tried our best. There is still a few flaws, but they'll get fixed.
i want to make a new windshield hoop too. Is that going to be hard? Or better yet, would it be worth the hard work and effort put into it. Since you know how low that loop sits.
is yours naturally 103"? or what did you do to it to make it 103"?
PostPosted: Wed Nov 12, 2008 8:25 am
i think mine was a 101 with stock arms,i put 2x3 arms on it made it 103,i think,that has been so long ago
PostPosted: Wed Nov 12, 2008 9:41 am
i would LOVE to be a wider buggy. My buddy has 3x3's and i want a pair REALLY bad
PostPosted: Thu Nov 20, 2008 9:21 pm
do you guys measure wheel base from center of back rim to center of front rim
PostPosted: Thu Nov 20, 2008 9:24 pm
yep
PostPosted: Fri Nov 21, 2008 12:25 pm
yeah. thats what we were planning on using. we used it on my buggy and its still together. what would you suggest?
PostPosted: Fri Nov 21, 2008 12:36 pm
.095 wall tubing
PostPosted: Fri Nov 21, 2008 1:04 pm
sch 40 pipe is a soft
you need DOM tubing 95 or 120 wall
JMO
PostPosted: Fri Nov 21, 2008 3:15 pm
schedule 40 could be used for light duty X bracing,but i use 120 wall dom on my roofs and rear cage,the rest of the car 095
PostPosted: Mon Nov 24, 2008 3:39 pm
Why would you add all that extra weight to end up with 1/3 the strength? Why would you jeperdise your life and or others to save a hundred Bucks? I really dont get it. :roll:
PostPosted: Mon Nov 24, 2008 6:46 pm
when i streched mine i used 095 it went from 92 inch wheelbase to 106 now with 2x3;s i even drilled holes in the frame slid the pipe in welded up the holes and around the cut its been 5 years this winter and not so much as a crack (so far) :lol:
Lets Ride!!!
PostPosted: Mon Nov 24, 2008 8:08 pm
095 is a little over 2.00 a ft here,ive never used sch.40 pipe,but if i wanted to make a front bumber out of it i would,thats about all i would do with it,i have seen complete buggys built out of it to
PostPosted: Tue Nov 25, 2008 12:32 pm
the reason why we are using the sec. 40 is that by grinding it down a bit it will slide right into the frame tubes. is there a dom tubing that will alide right into it?
PostPosted: Tue Nov 25, 2008 12:35 pm
wow
PostPosted: Tue Nov 25, 2008 12:47 pm
JeffClay wrote:
wow
wow what?
PostPosted: Tue Nov 25, 2008 12:53 pm
that comment.. yes there is tubing that will work and you want to slide a smaller piece of tubing inside the one end, weld it, slide the other end over it, and weld it all shut, if that makes sense, but yes trust me, there is the correct sizes of tubing out there, my frame is stretched 3 high and 3 wide all with tubing
PostPosted: Tue Nov 25, 2008 3:59 pm
where did you get it at?
PostPosted: Thu Nov 27, 2008 1:15 pm
Pics? Info? How did it go? What did you end up doing? I am looking at doing this to my 88" wheel base buggy. Hoping to stretch it out to 98" or 100". Thanks.
PostPosted: Thu Nov 27, 2008 2:38 pm
Havent made any progress at all. sorry budd. whats your email? i could send you pics of when we did mine. ill try and post them here after we get home in the a.m. from black friday :x Dont really want to go, but the womand wants too. haha
