It is currently Mon May 04, 2026 7:09 am
 Post subject: tube bender
PostPosted: Wed Oct 15, 2008 9:42 pm
Has anyone had experience with a jd2 bender and is this a good deal? http://cgi.ebay.com/JD2-Model-3-Tubing- ... 286.c0.m14
 Post subject: Re: tube bender
PostPosted: Wed Oct 15, 2008 9:57 pm
Thats the average deal. Don't forget that package doesn't come with dies. The JD2 is good for the hobbiest like most of us.
PostPosted: Wed Oct 15, 2008 10:03 pm
What is the best die 4.5,5.5,6.5.
PostPosted: Wed Oct 15, 2008 10:42 pm
I like the 4.5 my self but then your limited to tube thickness.
----------------------------------------------------------"Thickness"
100222 M3B Round Tube Die Set - 1 1/2" (4.5-90) 90 .095" $225
100223 M3B Round Tube Die Set - 1 1/2" (4.5-180) 180 .095" $265
100225 M3B Round Tube Die Set - 1 1/2" (5.5-90) 90 .083" $240
100226 M3B Round Tube Die Set - 1 1/2" (5.5-180) 180 .083" $280
100227 M3B Round Tube Die Set - 1 1/2" (6.5-90) 90 .058" $250
100228 M3B Round Tube Die Set - 1 1/2" (6.5-180) 180 .058" $290
PostPosted: Thu Oct 16, 2008 7:22 am
Thats what will kill you is all the dies I have 1.25 in 2 size an 1.5 in 3 size for tight bends and not so tight
I could have bought a compac car for what I spent :shock: :lol: :lol:
PostPosted: Thu Oct 16, 2008 9:47 am
i have this bender, it works great. i wouldnt want to build a complete frame with it, but for tree bars, extra bars on the frame ect.... its fine. i have the 11/2 -5.5x180deg. die and bend .095 no problem.
bendtech ez-3d computer bending program is also very helpful, just plug in your dimsions and it tells you where to mark and bend the material. very little wasted material this way. http://www.2020softwaresolutions.com/index.htm
i have an extra older program that doesnt have the 3d on it but still works for basic bending. i was gonna post it for sale, anyone intrested 40.00 for disc and book + shipping
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Oct 16, 2008 12:43 pm
Why wouldn't you want to build a whole frame with it?
PostPosted: Thu Oct 16, 2008 1:51 pm
Its a manual bender that requires a lot of manual labor! :lol: An Electric Hydraulic bender would be more suited for frame fab.
PostPosted: Thu Oct 16, 2008 3:40 pm
yea what he said
- Sigmund Freud
- Antonio Meloni
PostPosted: Thu Oct 16, 2008 11:13 pm
here is what i did for a bender cheap and not to much grunting http://www.youtube.com/watch?v=GWT3N3m4bE4 tell me how you like it :D
PostPosted: Fri Oct 17, 2008 2:35 pm
At about 20 bends per buggy it would take you the rest of your life to complete a car :shock:
PostPosted: Fri Oct 17, 2008 9:31 pm
I used the same bender for these, the front bumper broadsided a deer this morning and didnt bend
but the beam did!
PostPosted: Thu Jan 22, 2009 9:27 pm
I know I'm digging up old post but some may find this link useful, I know I did. It's a super easy way to lay out bends. As long as you start on the right direction of the mark.
http://www.pirate4x4.com/tech/bendin_tube/index.html
PostPosted: Fri Jan 23, 2009 5:40 pm
I just bought one. With a few dies. I was told try to get the dies with the smallest CRM or whatever the hell it called..
this buggy is built with it. Enough said its badass..
viewtopic.php?f=23&t=4403
PostPosted: Fri Jan 23, 2009 8:48 pm
CLR=Center Line Radius
I have two 1 5/8" dies one I bought has a 7" CLR and I built one with a 5 1/2" CLR. Both Afterburnt and myself didn't like the 7" for cage building. The bends are too large and sweeping so I machined one with 5 1/2". It bends much tighter. Think of the hoop behind your head, the 7"clr tube will be much closer where as the 5" will be higher out of your way. However the 7" is much better for the two tubes that comes horizonal off the trans mount up to the the rear most tube. you'll have a little more ground clearance for climbing.
Have fun with your new bender and all of the new friends that comes with it :wink: .
The link that I put up from Pirate4x4 makes it super easy to bend correctly.
PostPosted: Sat Jan 24, 2009 12:02 am
Yeah that Pirate4x4 info is very helpful. Ive read it many times..
