It is currently Tue May 05, 2026 10:35 am
 Post subject: Spring plate bushings
PostPosted: Fri Oct 10, 2008 8:56 am
I need to replace my rear spring plate bushings. I had the red poly ones in my old buggy and they squeaked like mad. Do they make better ones that don’t squeak? I found some rubber ones but they want $80 a side
PostPosted: Fri Oct 10, 2008 10:56 am
Something else to consider is the conversion,,,but make sure you get the real good heims..I fabbed up my own and they work great,,, before that I used neoprene bushings,,,my buggy squeeks everywhere anyway :?
PostPosted: Fri Oct 10, 2008 10:58 am
get the red poly ones cover them with anti seize
PostPosted: Fri Oct 10, 2008 11:28 am
You still running air bags or do you have torsion springs?
PostPosted: Fri Oct 10, 2008 5:14 pm
Get the YELLOW ones from McKenzies or SACO. They are way better than the red poly bushings. Coat them with the break in grease you get with them.
PostPosted: Sat Oct 11, 2008 4:34 pm
I’m running stock dual spring plate torsion with sway away bars. What do I need they have 2”, 1-7/8”, and 1-3/4” sizes listed on Saco? They also list them as Flange, Knobby or Round and the 2” are red. I haven't had time to pull it apart yet thats why I ask.
Check it out here
http://www.sacoautoparts.com/products.php?cat=28&pg=2
cron
