It is currently Mon May 04, 2026 3:20 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: Char Lynn
PostPosted: Sat Sep 06, 2008 6:07 am
Someone help me pinpoint the Char Lynn component I need to add power steering to my buggy. Or does anyone have it for sale,,thanks,,,I see a couple items on Ebay
 Post subject: Re: Char Lynn
PostPosted: Sat Sep 06, 2008 8:21 am
Iused a rack from a chevy malibu or saturn. Runs right off the suby pump!
PostPosted: Sat Sep 06, 2008 1:24 pm
The one Rock used is called a charrlynn torque genarator. If you look on ebay for charrlynn you can tell by if it looks like the steering shaft goes through it and has a place for two hydro ports. The regular charrlynn has a steering shaft on one end and two hydro ports and that's it no place for the steering to exit. And if you find a deal like buy one get one free, I need one too! My big heavy chaindrive and and my little 130lb butt need all the help I can get.
PostPosted: Sun Sep 07, 2008 1:05 pm
http://cgi.ebay.com/Char-Lynn-Tractor-Hydraulic-Steering-Torque-Generator_W0QQitemZ200250557421QQihZ010QQcategoryZ48718QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
PostPosted: Sun Sep 07, 2008 1:55 pm
Yea,,I got my eyes on that unit...Is this what I need?
PostPosted: Sun Sep 07, 2008 2:37 pm
That's it. Now go ahead and pick up me one too. Just kidding. That's a goooooood deal, you will need the port block and the mount for the charrlynn it's under 10 buck and not worth your time to make it for that much.
PostPosted: Sun Sep 07, 2008 10:08 pm
Well, I won it,,hope I didn't pay too much...sorry NC,,,just one in the deal :cry:
PostPosted: Mon Sep 08, 2008 12:05 am
Darn!!!! But it looks like your 100 or so to the good maybe more. Don't forget the port block for mounting the fittings and the mount for the box itself.
PostPosted: Mon Sep 08, 2008 9:00 am
I think McKenzies has all of the accessories you may need to complete the power steering system including the port block and mounts. I think some of the cheap distrubutors in Hot VWs are now selling the Charlynn parts (Moore parts or Pacific Customs).
PostPosted: Mon Sep 08, 2008 10:51 pm
firebug I used a piece of 1/2 in flat stock drilled 4 holes taped 2 pipe thread 2 to mount it with I know how you and your boy like to fab up stuff it will save 30 bucks takes 10 min to make
PostPosted: Tue Sep 09, 2008 6:27 am
I'm more concerned with weather or not to actually use the char lynn. I'm not sure my homemade front steering can take it. I am going to fab up an A-arm later and might as well at least try it though. :?
PostPosted: Tue Sep 09, 2008 10:08 am
Karen has ran one for years on a econo rack
put it on you will love it
PostPosted: Fri Sep 12, 2008 8:24 pm
Can I make my own couplers if I put it in line and have no need for U-jounts?
PostPosted: Mon Sep 15, 2008 1:21 pm
was out at Primm NV, this past weekend pitting for Baja Pits and General tire, anyway a buggy came into the pits with abroken Powe steering cylinder, where the cylinder attached to the .120 CM frame it peeled the tubling like and onion, it seems the system puts a huge strain at the poing the cylinder is mounted in the front, just thought id pass this on.
PostPosted: Mon Sep 15, 2008 2:01 pm
They do put a lot of stress on the frame mount. Mine flexs when I reach the stops.
PostPosted: Mon Sep 15, 2008 2:24 pm
i have had my beam move even though its clamped into the frame, when this happens the rack will stop but the ram wants to keep going to "it's" stopping point, this is when the ram becomes a log splitter and rips the mounting bracket right off. i had to weld stop tabs on the beam to keep it from shifting left or right.
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Sep 16, 2008 6:45 pm
Char lynn progress
PostPosted: Tue Sep 16, 2008 8:29 pm
I havn't hook mine up yet, but I was told you want to put the torque generator inline with your rack. It will eat u joints if not. I'm sure some of the guys here will chime in.....racebugg1098....
PostPosted: Wed Sep 17, 2008 12:25 am
Marty, I am LOVING the new driver in your buggy 8)
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."
Thomas Jefferson
Darlene
PostPosted: Wed Sep 17, 2008 6:49 am
Thanks,,,I been blowing her skirt up for several years now :)
PostPosted: Wed Sep 17, 2008 4:16 pm
I would agree with that logic. A solid splined coupler between the rack and Torque generator will be the strongest and last the longest.
PostPosted: Wed Sep 17, 2008 9:40 pm
That's what I like,,,input,,,,a little late but none the less ,,,input... I test drove today and I got mixed feeelings. I think for the woods this will be great ,,for everyting else,,,tricky :?
PostPosted: Wed Sep 17, 2008 10:24 pm
are we done here
PostPosted: Thu Sep 18, 2008 2:13 pm
I am now
PostPosted: Fri Sep 19, 2008 12:39 am
Why do you say that , 'bug??
Is it twitchy?? OR steer TOO fast? No feedback at all?
Jus' curious.
