It is currently Sun May 03, 2026 5:39 pm
 Post subject: making a msd box holder
PostPosted: Thu Aug 28, 2008 1:00 pm
hey i was wondering if any of you fellows might have a snazy way to protect a couple msd boxes on a buggy. im not at that point yet in my build but i thought i would ask ahead of time
PostPosted: Thu Aug 28, 2008 1:46 pm
I took a plastic case like a cordless drill comes in, cut out the stuff inside, drilled a couple ventilation holes in side and bottom, and there you go.
Not anything fancy that requires hours of fab work (that are lost forever), but....
Cheap easy light fast and it works fine.
PostPosted: Thu Aug 28, 2008 2:10 pm
Ammo boxs are great for that kind of stuff.
PostPosted: Thu Aug 28, 2008 4:40 pm
An MSD tech told me to keep it open to keep it cool, just protect it the best you can.
PostPosted: Fri Aug 29, 2008 12:54 pm
mine would shut down until i put in some vents for it.
the buggy would run fine then all of a sudden start missing and wouldn't start. wait 5 mintues and it would be back to perfect.
"Lets go get stupid"
PostPosted: Sat Aug 30, 2008 12:47 am
I run my open as well.... It is behind a piece of aluminum so it stays fairly protected... I also purchased the "Off Road" MSD box. I may have just wasted my money paying more for the "Off Road" MSD box but the "Off Road" version appears to be more weather resistant.
Here is the a link to the "Off Road" MSD box if you want to read more about it...
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD-6470&N=700+400122+115&autoview=sku
Good Luck
Dan
PostPosted: Wed Sep 03, 2008 12:39 pm
My MSD-6BTM is enclosed in an alumimun box and it works fine. It has not cut out after 4 rides.
PostPosted: Thu Sep 04, 2008 1:20 am
Only bad thing about the offroad box is no rev limiter, and limiter has saved my engine more than once.
They told me same thing about it needing air to cool.
PostPosted: Thu Sep 04, 2008 6:21 am
Hey Larry,
They actually do make an "Off Road" rev limiter that you can add. Although, the price just keeps going up.
Here is the one that I added to my buggy.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD-8769&N=700+115&autoview=sku
PostPosted: Thu Sep 04, 2008 8:20 am
i have always just run mine out of the way, and no problems yet. The other bad thing about the off-road box, is you can't get it repaired. you have to start over!
PostPosted: Thu Sep 04, 2008 11:08 pm
Hmmm... I was not aware of that but I guess I would have found out when I have a problem with my MSD box....
