It is currently Sun May 03, 2026 4:30 pm
PostPosted: Thu Aug 28, 2008 3:17 pm
does anyone have suggestions for cleaning and keeping wire terminals clean and dry? the only exposed wiring i have is on my coil, choke, idle cutoff, and starter jumper. non-ox only makes dirt stick. what about silicone?
PostPosted: Thu Aug 28, 2008 3:20 pm
Liquid electrical tape. drys to a plyable state.
PostPosted: Thu Aug 28, 2008 10:42 pm
Agreed, works real good. If you can't find it try Dip-it.
If your talking about RTV silicone I understand the chemicals in it attacks the metal in the solderless connector corroding it from the inside out.
PostPosted: Fri Aug 29, 2008 8:30 am
does the liquid tape "glue" the terminals on, or can you remove them without too much trouble?
PostPosted: Thu Sep 04, 2008 8:23 am
anyone?
how tough is it to remove terminals once this stuff is on there?
PostPosted: Fri Sep 05, 2008 9:18 am
No it does not glue them on. Its only a coating over the terminal. Sorry to get back to you so late.
PostPosted: Fri Sep 05, 2008 2:13 pm
thanks,
i-ll give it a try
