I emailed a megasquirt guy and he want all the info below,,,,I aint got a clue...I will just stick with the factory ecu for now
1. What year/make/model/engine/tranny? (Pretend you're at the parts store, ordering a starter.) If this isn't the original engine/electronics let me know that too.
2. Are you looking to control fuel only, ignition only, or fuel and ignition? Is there anything beyond these features that you are looking to control - fans or boost, for example?
3. What are the engine details (type, number of cylinders, previously fuel injected or carb'd?)
4. What type of ignition system does your car run- where is the crank angle sensor (CAS) or distributor trigger wheel and what type is it (Optical/LED Sensor? Hall Sensor? VR Sensor?)
5. How many teeth/windows/slots and what orientation does the CAS, crank trigger, and/or distributor wheel have? (any missing? all evenly spaced?)
6. Is there a distributor? Single/Multiple Coils? Coil on Plug?
7. Does this engine have a fast idle valve (IAC)? If so, how many wires are connected to it? Do you know if it is an on/off, pulse width modulated, thermal, or stepper type?
8. Rate yourself 1-5 on technical confidence in yourself. 1 being "I can't paint by numbers" and 5 being "I can probably build a car from scratch if I have the right documentation, and I'm resourceful enough to do some research and find some of my own answers." I need to know this as some of the 'less traveled' roads will require you to make modifications that in some cases I haven't performed myself yet and based on this response it will help me to know whether this type of solution is for you or not. I challenge you to 'stretch yourself' a little bit. You won't ever learn anything (about yourself and your abilities) if you don't try to do things that you're not quite sure you can do... and then find that you can.
9. Are you looking to build your own ECU from a kit or buy a pre-assembled ECU?
10. Are you open to retrofitting a different ignition system such as the Ford EDIS distributorless system or one of our crank trigger kits if it is determined that the MegaSquirt will not properly (or easily) control your factory ignition system? Many factory systems MegaSquirt can simply take control of, some it cannot. EDIS to the rescue! It's cheap, simple and works great!
If your clutch ain't slippin,, you probably got it adjusted right!!!!!
