It is currently Tue May 05, 2026 6:01 am
 Post subject: look at this
PostPosted: Sat Aug 02, 2008 10:50 am
the torsion is in backward,ive never seen it done like that before
http://cgi.ebay.com/ebaymotors/SANDRAIL ... 0246985790
 Post subject: Re: look at this
PostPosted: Sat Aug 02, 2008 11:21 am
Who would have ever thought that would work? You just never know....Now that is thinking outside the box :?
PostPosted: Sat Aug 02, 2008 1:22 pm
Thats odd. Wonder how it rides??
PostPosted: Sat Aug 02, 2008 4:42 pm
What does it have? One forward gear and four reverse!
PostPosted: Sat Aug 02, 2008 10:41 pm
yeah, he forgot to mention that in the ad. no wonder he has to get rid of some toys :mrgreen:
PostPosted: Sun Aug 03, 2008 1:33 pm
That is a good Idea! Think about it, he took a front wheel dr and moved it back. It still has all forward gears and reverse but there was not neough room for trailing arm susp. The front wheel dr motor sits a little to the front of the axle centerline so put the torsion in the other way. Its genius at work. The cvs bolted right up to the vw trans and the torsion just holds the weight. At 50 miles per gallon I would love to own it, if it were not for Pa laws. Its better than putting strut suspension in.
PostPosted: Mon Aug 04, 2008 5:02 pm
Trailing arms "trail" for a reason having them pivoting in the rear has to make the suspension act funny.
PostPosted: Mon Aug 04, 2008 8:12 pm
Your right, the way the trailing arm would hit somthing it would hit harder rather than ride over. But on the street who cares.
