It is currently Sun May 03, 2026 5:37 am
 Post subject: GM question
PostPosted: Wed Jun 25, 2008 9:11 pm
While I was Putting coolant in my buggy for the first time today.(It has a 4.3 v6 with a Moroso electric water pump) it started pouring coolant out of the un-used hole on the left side of the block.. my question is why and what do I do to remedy this the right way?
And buying a Ford/Dodge is NOT the answer I'm looking for!!! :lol:
 Post subject: Re: GM question
PostPosted: Wed Jun 25, 2008 10:39 pm
That is a bypass port. Tap it for a pipe plug and plug it off. Thats what I did on my v-8 fiero. It is not needed with electric pumps.
PostPosted: Thu Jun 26, 2008 1:04 pm
Thanks !!! Don't suppose you know the size of tap off hand do you?
PostPosted: Sun Jun 29, 2008 8:51 pm
go to the auto parts store and by some small freeze plugs that will do the trick.
PostPosted: Sun Jun 29, 2008 9:01 pm
I used a small 1/8 npt inch pipe plug worked great with teflon tape.
PostPosted: Sun Jul 06, 2008 6:33 pm
Make sure you use GM gaskets for the waterpump. The felpro and other aftermarket gaskets I've had blow out. This happened to me twice. And yes, I was tightening it correctly. The torque spec is 33 ft lbs for the water pump bolts.
John
