It is currently Mon May 04, 2026 11:10 am
PostPosted: Sat Jun 07, 2008 7:49 pm
Whats the biggest crank I can use in a stock block? I have 94 piston with a stock crank which is a 1914. What is the calculation for the CC size?
I just want to be able to put in the largest motor without having to cut the block.
The Wild Kids
PostPosted: Sat Jun 07, 2008 8:34 pm
Try this engine calculator..http://davisracing.com/engine%20calculator.htm Thanks Dave T
PostPosted: Mon Jun 09, 2008 3:24 pm
The Wild Kids
I think you are stuck with the 69.
Even a 74 crankshaft would require a bit of case trimming.
PostPosted: Mon Jun 09, 2008 10:47 pm
Will the 74 fit without having to align bore it and just clearance the sides? Or even a larger crank without having to align bore.
The Wild Kids
PostPosted: Tue Jun 10, 2008 11:17 am
The Wild Kids
Align boring and crankshaft clearancing are two different operations.
I can almost say any engine case with a fair amount of time on it will need align bored no matter what your plans are.
Align boring is the process of machining the main bearing tunnel through the case to correct any "pounding" that usually occurs in a magnesium case.
This is the surface where the bearing locates after align boring.
Crankshaft clearancing is just that, removing material in the case to swing a larger than stock crankshaft.
Here is an example.
How far you need to go depends on how big the stroke is.
IMHO if you are gonna clearance one for a stroker crank, might asa well be a big one.......... :mrgreen:
One other thing, if you go bigger than about 76, you'll need to clearance the camshaft too.
PostPosted: Tue Jun 10, 2008 12:46 pm
We also had to clearance the crank with my 84. The counterweights would hit the cam lobes.
Kyle
"Lets go get stupid"
PostPosted: Tue Jun 10, 2008 1:41 pm
Kyle
What crank do you use Kyle?
Had issues with 86 and 88s but never an 84......... :?
PostPosted: Sun Jun 15, 2008 12:38 am
78 is the largest that I can use without boring it for a stroker. I know that I will have to clearance for the balancers to clear. So what would a 78 crank and 94 pistons give me?
The Wild Kids
PostPosted: Sun Jun 15, 2008 1:07 am
The Wild Kids
78 stroke 94 bore makes 2165cc
Travis
PostPosted: Sun Jun 15, 2008 11:08 am
Thanks Travis, How did you come up with that? I have tried and never get it right. I am missing a step in the calculations.
The Wild Kids
PostPosted: Sun Jun 15, 2008 3:14 pm
The Wild Kids
Try this engine calculator http://davisracing.com/engine%20calculator.htm
Travis
