It is currently Sun May 03, 2026 6:39 pm
 Post subject: ? about a super diff.
PostPosted: Thu Apr 19, 2007 7:24 pm
I have gotten a hold of a perfect running 5 rib and was wondering what exactly a super diff. does? and the advantage is with having one. I like the gearing of the 5 rib compared to the 6. :twisted:
PostPosted: Thu Apr 19, 2007 7:31 pm
Its similiar to putting a posi unit in a rear drive front engine car. Makes both wheels drive instead of just one, but its not solid , like a spool. In other words there is limited slippage. It is also much stronger, partially because there are four spider gears instead of just two. Roy can explain much more in depth, if you need to know more.
PostPosted: Thu Apr 19, 2007 9:14 pm
[quote='Railboy']I have gotten a hold of a perfect running 5 rib and was wondering what exactly a super diff. does? and the advantage is with having one. I like the gearing of the 5 rib compared to the 6. :twisted:[/quote]
A 5 rib is a great choice to run. The ring gear is much stronger than it's 3 rib cousin.
To make a 5 rib last in the woods, I would install a 6 rib super diff in it. You can install one for about 500 bucks turn key.
A super diff is a must if you run the
PostPosted: Thu Apr 19, 2007 11:46 pm
hey roy
whats the difference between a 002 super diff and a 6 rib super diff?
i got my 5-rib broken down because reverse is almost gone, looking for a strong cheap fix.
i can get an 091 super diff for 350 bucks and a 002 super diff for $170.
i kinda want to go the cheap route.
PostPosted: Thu May 03, 2007 2:09 pm
[quote='bhallOU']hey roy
i kinda want to go the cheap route.[/quote]
There are several differences between the 002 super diff. and the 091.
Both are major improvements over using a stock one. If you like to run your buggy hard and y
PostPosted: Mon May 21, 2007 8:37 pm
A superdiff increases strength of the spider gear section. It slighty performs a posi action, but very little. The stock diff/spider gears are usually the first weak link in VW transmisisions.
Eric
PostPosted: Mon May 21, 2007 9:05 pm
Its great to see you on this site Eric. I learned alot off your web site.
PostPosted: Tue May 22, 2007 4:48 am
I too am glad to see Eric DeBord over here. Thanks for visiting Eric and I hope you stick around. For those of you that might not know him, he is probably one of the best and knowledgeable transaxle builders in the country.
Roy
 Post subject: Trans rebuild
PostPosted: Tue May 22, 2007 2:21 pm
Ah Eric a name from the past. Eric was a big help to me when I changed out a 388 to a 411 R & P in a sedan trans when I got into the Hobby. Thanks Eric Glad to see ya here.
PostPosted: Thu May 24, 2007 8:30 pm
Thanks guys!! Glad to be here. :)
PostPosted: Thu May 24, 2007 8:50 pm
welcome eric hope to see you at d and k
PostPosted: Thu May 24, 2007 9:37 pm
Yea Eric come on to D&K and ride with us all. Be glad to finally meet you.
The Wild Kids
