It is currently Sun May 03, 2026 10:56 pm
 Post subject: 914 disc brakes
PostPosted: Sun May 18, 2008 7:58 pm
:? I have access to the disc brakes off a '71 914 and was wondering if they would fit anything VW and if so what years and what types---BJ or LP--IRS or SA.....Thanks guys
My goal is not to arrive at the grave safely in a well preserved body,but,rather to slide in sideways,totally worn out,beat to hell,shouting "Holy Cow!!What a Ride!!"
 Post subject: Re: 914 disc brakes
PostPosted: Sun May 18, 2008 9:10 pm
I have used the rear hat style rotors on the rear of my old buggy. If that helps at all
PostPosted: Mon May 19, 2008 4:34 am
I agree. The rear rotors can be easily used for an inexpensive disc brake conversion. :wink:
PostPosted: Mon May 19, 2008 9:46 pm
I was in the shop saturday just messing around and decided to take the brakes off the rear trailing arm of the 914---got to wonderin' if the rotors and calipers would fit on a VW trailing arm--I'll get in the shop and take the VW arms apart and see what fits..if it does I'll just have to rebuild the calipers....thanx guys
PostPosted: Fri Sep 19, 2008 7:58 pm
The 914 front rotor bolts right onto a ball joint spindle. You would of course have to come up with a caliper mount.
John
