It is currently Mon May 04, 2026 12:38 am
 Post subject: 3 rib ring & pinion
PostPosted: Fri May 02, 2008 3:45 pm
I have a friend that lost a pinion bearing and trashed his pinion gear. He called and left a message at Weddle but until then does anyone know what a new Ring and pinion costs? It is the acorn nut trans.
 Post subject: Re: 3 rib ring & pinion
PostPosted: Fri May 02, 2008 4:41 pm
The acorn nut style is VERY weak, imo, due to the bearing setup. I would at least switch it over to the later style. 3-rib R&P's in general are weak as well, but I have seen some of them last for a long time.
PostPosted: Fri May 02, 2008 5:50 pm
I will sell you the whole transmission for 200 dollars. I have one of those and I will never use it. I can bring it to the party in 3 weeks.
PostPosted: Fri May 02, 2008 7:55 pm
Eric:
What all does it take to convert it to the later style?
Roy:
Ill give him a call. He may be interested in that. I won't have my buggy ready but was looking for a reason to come down to the party since i bought raffle tickets. This just might be a good excuse.
He is only running a 1641 with cut Mickey T baja claws so I don't think he will have to many problems out of this trans even though it is the weaker one.
PostPosted: Sat May 03, 2008 8:19 pm
A late style case (3, 5 or even 6-rib will work-6 rib needs reverse idler shaft changed), the late style pinion bearing, nut and washer. You will also need the threaded bearing retainers (that hold the diff), locks, and philips headed screws. I think that is all....
backwoods wrote:
Eric:
Roy:
PostPosted: Mon May 05, 2008 3:55 pm
He just wants to fix it and get it back together then look for something better.
Where should he order the parts? Is Weddle's number 805-562-8600? He said they only sell used? Also they did not have the pinion bearing.
Thanks for the help guys.
PostPosted: Tue May 06, 2008 8:11 am
Is this for plumber Chris from Walhonding? If it is tell him I’m still waiting for my tranny parts back. 6months is getting to be a joke and he can’t even call me WTF.
PostPosted: Tue May 06, 2008 9:06 am
Nope not plumber chris. I havn't seen him since last year. Krist talks to him all the time I think, you might see if he can get ahold of him. This is that friend of mine C.J. that has the fifth wheel in my section with the red buggy.
PostPosted: Wed May 07, 2008 8:37 am
Yea I have called Chris twice a week for the past 6months and he doesn’t return my call. I talk to Krist all the time and he has told Chris several times to get in touch with me and he still hasn’t. He was going through a divorce so I understood why he didn’t call the first couple months but 6 months to just return my call and let me know what was going on is a little excessive. If you see him before I do let him know I am STILL waiting for my parts.
PostPosted: Wed May 07, 2008 1:08 pm
Will do. He might be down there this weekend.
PostPosted: Thu May 08, 2008 2:27 am
I have a couple R&P for the acorn 3rib I'd sell him 1 tell him to get a hold of me
