It is currently Mon May 04, 2026 10:36 pm
PostPosted: Fri Apr 18, 2008 8:06 am
Where do you all get em and what size are they. I have a standard size shaft and am at work so i can't measure but wanting to pick up a u-joint and a couple of bearing blocks on the way home.
Thanks
Bryan
PostPosted: Fri Apr 18, 2008 8:20 am
most buggy shops carry the standard 5/8" (i will assume thats what you have). Race shops like Summit carry them. Automotive parts houses and tractor supply, farm and fleet may.
PostPosted: Fri Apr 18, 2008 8:33 am
So 5/8 is the steering shaft OD? Or is it a 5/8 u-joint? Thanks :)
Bryan
PostPosted: Fri Apr 18, 2008 9:12 am
I just measured a new shaft I have and the OD is 0.875" and the ID is 0.665
PostPosted: Fri Apr 18, 2008 9:44 am
I stand corrected. I did a little research and the 5/8" is typically a splined weld on shaft. Steering shafts are avalable in 3/4" and 7/8". My new buggy is using 3/4" shafts with and with out splines.
PostPosted: Fri Apr 18, 2008 10:15 am
Thanks!!!
Bryan
PostPosted: Sat Apr 19, 2008 10:15 am
Don't know if this will help you, but here is where I bought mine.
http://www.speedwaymotors.com/p/2031,17 ... oints.html
They had more than they list on their site.
Users browsing this forum: Majestic-12 [Bot] and 0 guests
