It is currently Tue May 05, 2026 4:49 am
 Post subject: Shifter set-up
PostPosted: Tue Apr 15, 2008 2:16 pm
Hey guys,
I was wondering if anyone had some pics of there shifter setups. Do you have to have the shaft on the shifter perfectly aligned with the rod on the trans. So would you have to have some kind of riser to set your shifter on.? Also if anyone has some pics of there cutting brakes setup i could use some ideas. This is the next step in my build and could use some ideas.
Thanks always
Nick
PostPosted: Tue Apr 15, 2008 2:21 pm
One thing to consider it tilting the tranny. Get it tilted as much as you like with the cv flanges still in stock location. Then try to keep the shifter rod fairly strait with the tranny. I actually used one shifter box slipped over another shifter box. One of many opinions , I'm sure. 8)
PostPosted: Tue Apr 15, 2008 2:33 pm
nick here is my old setup. shifts very smooth. i just built a little tunnel for the cutters to set on and extended the shifter rod. my rod just lays on the floor and the shifter ball just goes in the cup. i never raised the rod up into the shifter or anything.
"Lets go get stupid"
PostPosted: Tue Apr 15, 2008 9:39 pm
In all of my previous buggies we bent an "S" into the shiftrod so it lined up with the trans. Sorry, dont have any pics. It shifted ok like that but never really felt right if you know what I mean. Put it this way, Im glad the shift rod in my baja is going straight into the trans
Jim
D. Marks wrote:
The only time I hug trees is while I'm carring them out of the way.
PostPosted: Wed Apr 16, 2008 12:34 am
i just double stacked the boxes the shifter sits on and works great
PostPosted: Wed Apr 16, 2008 2:46 pm
So you want the rod from the shifter at pretty much exactly the same height as the rod coming out of the nose cone?
PostPosted: Wed Apr 16, 2008 5:54 pm
If you tilt (slope) the tranny the shifter rod will also be tilted (sloped) and the shifter box will be tilted (sloped) . Line them all up and the shifter will work smoother. Thats my story and I'm sticking to it :roll:
PostPosted: Wed Apr 16, 2008 8:46 pm
I see thanks for for all the input guys. Mine does have a little slope in it (trans) so i will make the adjustments with the shifter. But you do want the shifter rod the same height as the trans nose cone rod correct??
PostPosted: Wed Apr 16, 2008 9:50 pm
I'm thinking that if the tranny slopes then the shifter rod will slope also and therefore the shifter rod will not be parallel with the buggy frame , hence the shifter will be closer to the frame not the same height. 8)
PostPosted: Wed Apr 16, 2008 10:00 pm
Basically if the tranny tilts everything else has to tilt with it nose cone rod, shifting rod, shifter platform, shifter rod everything. Well i think were all starting to over analize this i got it figure out so thanks for all the answers guys
PostPosted: Wed Apr 16, 2008 11:48 pm
I wish I had pics, mine was set up with two u joints and set down to the right of the old box. It worked great.
PostPosted: Thu Apr 17, 2008 8:09 pm
i just raised mine because the shift rod sat at a downward angle and the ball on the bottom of the shifter bearly went down in and it was real sloppy i used 1 1/2 angle iron and made a box |_| like this left it open toward the rear no reason but it raise it 1 1/2 and shifts smooth and it is tight now also it works well if that helps
PostPosted: Thu Apr 17, 2008 9:21 pm
i just did mine to bolt to a six rib and all we did was tilt the shifter box down in the front and re weld it and it worked just fine.
kevin
Ridin' in a souped up honda is kinda like ridin' the short bus, no matter were ya go someone is lookin' at ya!
PostPosted: Fri Apr 18, 2008 8:59 am
My old rail I did an S curve but it was hard to get it adjusted. The new rail has a high shift box and the shift rod is straight and looks a little simpler to get adjusted correctly.
Old rail.
PostPosted: Mon Apr 21, 2008 12:39 pm
a friend had the same problem with the ball not reaching the shifter. he welded a socket on top of tht shifter . been 2 years and it still works fine.
