It is currently Mon May 04, 2026 4:38 pm
PostPosted: Tue Mar 18, 2008 8:12 pm
From what year of Bus/Vanagon, and type of trans, did VW use a 19 1/4 inch long axle? I'm trying to locate some for a buddy that recently got some 3x3 trailing arms. Thanks!
PostPosted: Tue Mar 18, 2008 8:13 pm
No bus that I know of has that length. Aftermarket would be your only option.
PostPosted: Tue Mar 18, 2008 9:00 pm
stock bus axels should work
PostPosted: Tue Mar 18, 2008 9:33 pm
The stock axles from the Buses with 3, 5, and 6 rib trannies are 18 3/4, which I though only worked with 2 X 3 arms. I've spoken with a few people that say the 19 1/4 axles come from a Vanagon, but when you ask them from what year, with which trans, they don't have any idea. I found some from a 91 Auto Trans Vanagon, and they were different lengths that were both over 20 inches long.
PostPosted: Wed Mar 19, 2008 7:43 am
you can just get the empi set, they are reasonablely priced
PostPosted: Wed Mar 19, 2008 9:53 am
Yeah, I've been trying to find some used ones for a little while now. Not really any to be found (as Roy said, they aren't stock). I think I'm gonna have to buy some new ones(about $135).
Get me that hammer, pronto!
PostPosted: Wed Apr 02, 2008 9:37 pm
i need them also i know appletree automotive carrys them. 130 for the set. the site is www.appletreeauto.com number is in hot vw's
kevin
Ridin' in a souped up honda is kinda like ridin' the short bus, no matter were ya go someone is lookin' at ya!
PostPosted: Thu Apr 03, 2008 9:22 am
Ebay has some.
http://cgi.ebay.com/ebaymotors/sand-rai ... 0208661613
PostPosted: Thu Apr 03, 2008 7:03 pm
You can run stock bus axles 18 3/4 out of a 70-79 bus just add a1/2 inch spacer on your stub axle
PostPosted: Thu Apr 03, 2008 7:06 pm
VW made 19-1/4" axles just not sure what they came out of.
I've had several sets in here.
Maybe Vanagons??
PostPosted: Thu Apr 03, 2008 8:01 pm
[quote='sharpshooter']You can run stock bus axles 18 3/4 out of a 70-79 bus just add a1/2 inch spacer on your stub axle[/quote]Never heard that one before!
PostPosted: Thu Apr 03, 2008 8:16 pm
It works,it puts your stub axle in toward your tranny flange making up for the 1/2 inch difference in the axle 18 3/4-19 1/4 axle
PostPosted: Thu Apr 03, 2008 11:25 pm
i put bus axles in my 3x3 trailing arms... i think i used the 1/4 inch spacers on the stub axles ( no sure tho ).. you probably wont be able to put the cotter pin back in the nut but i didnt have any problem with them loosening up.. just check em the first couple rides.. its a better way to go unless up want to spend mo money. i never had any problems..
PostPosted: Fri Apr 04, 2008 8:39 am
[quote='bhallOU']i put bus axles in my 3x3 trailing arms... i think i used the 1/4 inch spacers on the stub axles ( no sure tho ).. you probably wont be able to put the cotter pin back in the nut but i didnt have any problem with them loosening up.. just check em the first couple rides.. its a better way to go unless up want to spend mo money. i never had any problems..[/quote]How does the inside seal work?
PostPosted: Fri Apr 04, 2008 5:38 pm
i'm sure its not as good of a seal against the spacer as the stub axle, but it works. i never had any grease problems.. that was one of my first alabama rig jobs on a buggy. :D that was a couple cases of beer ago since i did that.. i have forgotten exactly how it seals..
