It is currently Sat May 02, 2026 11:28 pm
 Post subject: Wiring Diagram for A/C
PostPosted: Wed Apr 02, 2008 4:58 pm
PostPosted: Wed Apr 02, 2008 8:17 pm
Thanks!!
Bryan
PostPosted: Wed Apr 02, 2008 9:03 pm
That would be a good post to make "Sticky", so it would always be right at the top of the forum for anybody wiring one for the first time!
PostPosted: Thu May 14, 2009 4:44 pm
could someone please put a diagram up for the generator sys. again -- i cant remember how the vol. reg. wires up
PostPosted: Tue Mar 23, 2010 8:41 am
sorry to ask a dumb questionb ,but i am havn trouble with my coil i have power to both sides +and- . i tried 2 differnt coils and the same thing happened. looked at the wiring diagram and it is wired right. got me stumped. if anybody can help me out i would apprciate it . thanks
PostPosted: Tue Mar 23, 2010 9:40 am
I don't think you want power to both sides of the coil,,,one should be ground (earth).
PostPosted: Tue Mar 23, 2010 10:27 am
The small wire on the distributor (from condensor, green or black if its bosch) goes to - side of the coil.
Switched hot wire from ignition switch goes to + side of coil.
If u r hot on both sides of the coil, gonna fry it, plus no way to get a signal from the dist. to fire the cap.
PostPosted: Thu Mar 25, 2010 10:02 am
Thanks guys for the advice. Found out its was the condensor. Go figure :lol: thank again for helpn me out. Hope to see u guys in the woods.
PostPosted: Mon Jul 12, 2010 2:52 am
Just wondering how to wire the disconect switch so that it functions as a kill switch. Would you run B+ from alt. to battery side of disconect switch instead of to the starter? Since you can take a battery out of the circuit once the vehicle is running as alt will continue to provide 12V.
PostPosted: Thu Nov 10, 2011 5:39 pm
how about for the reverse lights off the trans? is it wired like the inline brake switch. permanent + on one side and the feed out on the other?
if it aint broke don't fix it
PostPosted: Thu Nov 10, 2011 9:39 pm
It is the same as the inline brake switch, just double check the switch with an ohmmeter to verify switch is OK before wiring it up....
PostPosted: Sun Nov 13, 2011 9:15 am
thanks. was curious
PostPosted: Sat Apr 05, 2014 8:14 am
I cleaned this up a little for my printer at home, its a little clearer and only black and white, I printed it at 200% scale and it fit on a regular piece of paper (so I could have it on hand in the buggy).
