It is currently Sun May 03, 2026 5:38 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
 Post subject: SUBY PROGRESS
PostPosted: Sat Feb 09, 2008 12:09 am
Finally got Suby mounted
[img][img]http://i223.photobucket.com/albums/dd87/jem203/IMG_2466.jpg[/img]
[/img]Image
[img][img]http://i223.photobucket.com/albums/dd87/jem203/IMG_2459.jpg[/img][/img]
PostPosted: Sat Feb 09, 2008 12:42 am
Fits nice and looks good. What do you plan to use for coolant lines? I have been working on them myself.
PostPosted: Sat Feb 09, 2008 1:10 am
buggy looks good steve
ps you can fix stupid--its just illegal to do it
PostPosted: Sat Feb 09, 2008 7:01 am
It's a thing of beauty. that left tire on the last pic looks real light. You just gave a secret away. I wish I had thought of tilting my engine like you did. 8)
PostPosted: Sat Feb 09, 2008 9:23 am
looks good steve. where are you mounting the radiator. what are you doing with the exhaust.
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Feb 09, 2008 10:14 am
Hey Steve I see you still have a Yellow trans in there You are going to remove the Taboo color are you not? And no you can not paint over it that will just hide the damage inside. Keep us posted on your progress.
PostPosted: Sat Feb 09, 2008 11:28 am
[quote='plumberbill']looks good steve. where are you mounting the radiator. what are you doing with the exhaust.[/quote]
Dave and I are trying a few things to see if we can build a headrer style exhaust to look like a v-dub pipe. As for the rad we are looking at several different styles of rads and Im not sure whitch one to use yet. I've been busy with work and finishing the apt above my garage to rent out. Its good to finally work on it again. Hows your buggys comin along?
PostPosted: Sat Feb 09, 2008 1:13 pm
Hill Climber
That looks real good Steve.
Harry S. Truman
PostPosted: Sat Feb 09, 2008 5:46 pm
[quote='Steve'][quote='plumberbill']looks good steve. where are you mounting the radiator. what are you doing with the exhaust.[/quote]
Hows your buggys comin along?[/quote]
wiring harness is on the way back from enginewiring.com motor is ready to go in, just waiting for the harness
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Feb 09, 2008 11:17 pm
By the way I weighed both motors and I gained 42 pounds over the stroker motor. Not too bad , huh?
PostPosted: Sun Feb 10, 2008 9:21 am
[quote='fortydegnorth']Fits nice and looks good. What do you plan to use for coolant lines? I have been working on them myself.[/quote]
A buddy of mine has a pipe bender for exhaust, we are goin to bend up some cooling lines. I would like to use aluminum pipe but dont know if we can bend it without kinking it.
PostPosted: Sun Feb 10, 2008 10:37 am
I wondered the same thing. I decided to use 1.5" stainless. The problem with stainless is I had to buy a whole 20' stick. If you decide to go stainless let me know I should have some left over! That is unless I totally screw something up, which is likely. I went 1.5" because I have a bender with that die.
PostPosted: Sun Feb 10, 2008 10:55 am
I've been told that stainless bends good depending on if 304 or 403 what ever the numbers are. If you fill it with light sand it wont kink. There is a web site that has v-8 in their buggys and there runing small lines through the 1.5 tubes with an fittings. What engine are you putting in? I got ahold of a oil cooler from an excavator that is all alum. I might try to use it as a rad or use a scirocco rad not sure yet.
PostPosted: Sun Feb 10, 2008 11:12 am
looks good .what kinda rear brakes are you running?
PostPosted: Sun Feb 10, 2008 11:36 am
[quote='purplerail']looks good .what kinda rear brakes are you running?[/quote]
The brakes are a set from empi, I think? they have emergancy brakes on them. I was in a shop this week and I belive they are the same as mustang rear brakes around 94 year car. Pads and calipers lokk identical
PostPosted: Sun Feb 10, 2008 2:09 pm
I'm running a 2.3L Ford Turbo. My bender is a mandrel bender so it shouldn't kink anyway. The stainless is 304. There is also 316 but I really don't know the difference.
PostPosted: Sun Feb 10, 2008 4:07 pm
The amounbt of carbon in the metal. 316 has less carbon than 308,304 and so on. stick a magnet to 304 it will attract to it.
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Sun Feb 10, 2008 4:11 pm
[ A buddy of mine has a pipe bender for exhaust, we are goin to bend up some cooling lines. I would like to use aluminum pipe but dont know if we can bend it without kinking it.[/quote]
summit racing has s.s. corrigated radiator hose up to 48" if you dont want to bend stainless pipe http://store.summitracing.com/partdetai ... toview=sku
- Sigmund Freud
- Antonio Meloni
PostPosted: Sun Feb 10, 2008 5:18 pm
www.woolfaircraft.com
mandrel bent aluminum, stainless tubing, this where I got my stuff.
Don't waist your time bending aluminum tube unless it's heavy wall, you'll crush it before you'll bend it.
ALSO remember www.mcmaster.com you can buy short lengths of tubing I use them all the time for stuff like that.
PostPosted: Sun Feb 10, 2008 11:21 pm
[quote="MadMike"]www.wolfaircraft.com
might want to double check the web address, link dosn't work
- Sigmund Freud
- Antonio Meloni
PostPosted: Sun Feb 10, 2008 11:25 pm
I'll learn to spell som day
PostPosted: Sat Mar 15, 2008 11:28 pm
I guess I need to post an update, huh? Well here it is Dave has helped a great deal! This would not be anywhere near this point if I did not have his help. Thank you Dave, its a privlage to have your expert fab work on my car. We added some x-braces and are ready to mount the seats. I also have to thank Jason for his help and Mike for all the info on Suby swaps.
[img][img]http://i223.photobucket.com/albums/dd87/jem203/IMG_2578.jpg[/img]
[/img]Image
[img][img]http://i223.photobucket.com/albums/dd87/jem203/IMG_2581.jpg[/img][/img]
PostPosted: Sun Mar 16, 2008 12:05 am
nice job steve.........when your done with dave send him to cleveland to help in my garage :)
- Sigmund Freud
- Antonio Meloni
PostPosted: Sun Mar 16, 2008 7:26 am
Looks good Steve. Coming along very nicely.
PostPosted: Sun Mar 16, 2008 11:52 am
Steve that looks very nice :D
