It is currently Sun May 03, 2026 10:57 am
 Post subject: Torsion bars
PostPosted: Mon Apr 23, 2007 10:44 pm
What size torsion bars are you guys running with 3x3 arms? I have 29mm ones and am starting to think they may be too stiff. I dont want it to ride like a tank, but I will probably be doing alot of jumping.
Im thinking about keeping my stock set for when I make trips up north to ride with you guys. Would those work or be too weak for the 3x3s?
PostPosted: Tue Apr 24, 2007 2:49 am
What length bars are they? if there like 26" you should be ok,have you weigh'd it yet or have a close est? mudd
PostPosted: Tue Apr 24, 2007 4:44 am
I have 28mm in mine and they are perfect for me.
PostPosted: Tue Apr 24, 2007 4:09 pm
Im not sure about the weight. Im guessing its probably gonna end up weighing about the same as a regular baja. I think I added as much weight in tubing as all the metal that was removed so Im guessing around 2000 lbs :cry: If Roy is happy with the 28s then the extra weight ought to make my 29s pretty good
PostPosted: Tue Apr 24, 2007 8:35 pm
Run them for a while. You will like them.
Roy
