It is currently Mon May 04, 2026 4:45 pm
 Post subject: my buggy
PostPosted: Fri Feb 22, 2008 10:26 pm
Imagethis my buggy that is powered by a ford 2.3
RIDE HARD-PARTY HARDER
PostPosted: Fri Feb 22, 2008 11:15 pm
I think you need a little more air in that right rear tire
a seven day honey moon makes a hole weak
PostPosted: Fri Feb 22, 2008 11:43 pm
Seen that but didn't say anything about it. Where do you ride at?
The Wild Kids
PostPosted: Sat Feb 23, 2008 12:06 pm
[quote='The Wild Kids']Seen that but didn't say anything about it. Where do you ride at?
The Wild Kids[/quote]they are just inflated to the rated psi off of the tire 32psi thats all why? they seem to do just fine i havent had any trouble
been up hill,down hill,flat land,and through ponds even rode in the rain
i havent got stuck yet
PostPosted: Sat Feb 23, 2008 12:08 pm
[quote='danny']I think you need a little more air in that right rear tire[/quote]thanks dude i think you just started something
PostPosted: Sat Feb 23, 2008 1:31 pm
In my rear I have about 7 psi from are about 15 maybe. If you have beadlocks you can take it down to 2 or 3 psi in the rears.
The Wild Kids
PostPosted: Sat Feb 23, 2008 1:39 pm
[quote='The Wild Kids']In my rear I have about 7 psi from are about 15 maybe. If you have beadlocks you can take it down to 2 or 3 psi in the rears.
The Wild Kids[/quote]yeah i dont have bead locks and my tires are 29 12x50 15 i bought from douglas wheel and tire they are not big but i like the performance of them maybe when they wear out i will get bigger ones like most of you all have.
PostPosted: Sat Feb 23, 2008 2:03 pm
they were raggin on you cause you have so much air in them--most of us only run about 6 to 15 psi in the rears--it makes em bite harder and flex more
PostPosted: Sat Feb 23, 2008 3:44 pm
[quote='harleyhunter05']they were raggin on you cause you have so much air in them--most of us only run about 6 to 15 psi in the rears--it makes em bite harder and flex more[/quote]i can air them down maybe but they are pretty stiff tires and i was affraid they would slip on the rim
they seem to grip good know but anything is worth a try
PostPosted: Sat Feb 23, 2008 4:00 pm
i've ran 29x15.5x15 tractors, and im running 30x12.5x15 tractors now--i use tubes in them--they do fine, i've only had 1 come 0ff the bead in 5 years---both sets were 8 ply
PostPosted: Sat Feb 23, 2008 4:21 pm
[quote='harleyhunter05']i've ran 29x15.5x15 tractors, and im running 30x12.5x15 tractors now--i use tubes in them--they do fine, i've only had 1 come 0ff the bead in 5 years---both sets were 8 ply[/quote]i will try it then thanks
