It is currently Tue May 05, 2026 9:10 am
 Post subject: Front tires info.
PostPosted: Tue Feb 19, 2008 10:20 pm
Does anyone know where to get the front tires that quite a few people are running,i think they are called Hay rate.They are a knobby type tire.I want to make sure that i'm pronouncing the name correct.I live around the Mt.Orab,Georgetown,Milford.Ohio. I also go to KY quite often if you know a place .
PostPosted: Tue Feb 19, 2008 10:26 pm
I think they were refering to hay rake* tires?
Shine is fine, but flats where its at
PostPosted: Tue Feb 19, 2008 10:45 pm
These??
PostPosted: Wed Feb 20, 2008 8:08 am
Those are close. They have a sideway's V-pattern on the outer edge.But that name sounds better.
PostPosted: Wed Feb 20, 2008 8:19 am
i have 4 ply 760 15 firestones v tread like sharpshooter has. look at his pics
PostPosted: Wed Feb 20, 2008 8:35 am
check this link
http://forum.woodsbuggy.com/viewtopic.php?t=2667
PostPosted: Wed Feb 20, 2008 9:16 am
They call them home plate tires also.You can get them at Drews.
PostPosted: Wed Feb 20, 2008 9:52 am
You can go to any tire store that sells farm implement tires. They are the tires they use on Hay Rakes. Older hay rakes are powered through a chain (i think) connected to the wheel (a backwards chain drive lol) so it has to have traction to turn the rake, thats why they are knobbed. Dunno the size right off hand, I have it written down somewhere just gotta find it.
Bryan
PostPosted: Thu Feb 21, 2008 7:42 pm
Traction implement tire is what they are called. Here is a link to where you can get some. Look under the traction implement section.
http://www.millertire.com/
PostPosted: Thu Feb 21, 2008 9:02 pm
Those are the ones,thanks guys.
PostPosted: Thu Feb 21, 2008 10:30 pm
[quote='bruce 1']Traction implement tire is what they are called. Here is a link to where you can get some. Look under the traction implement section.
http://www.millertire.com/[/quote]
It would be nice if they made those in 16 inch...
PostPosted: Fri Feb 22, 2008 4:21 pm
I run these as well. You can go to any Goodyear/Firestone dealer and get them. They are miles better than a ribbed tire.
Where did you say the weenie trail is?
cron
