It is currently Sun May 03, 2026 8:23 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: Exhaust?
PostPosted: Sat Feb 16, 2008 10:56 pm
How are guys running your exhaust?? I'm trying to figure the pipes out and I'm not sure which way to go. Any ideas? Oh please post pics.
PostPosted: Sat Feb 16, 2008 11:02 pm
Do you think header style exhaust would work with the fuel injection?
PostPosted: Sun Feb 17, 2008 12:18 am
I used a Camco Fab Bombshell muffler for my exhaust. Mine was pretty easy since its turbo the exhaust manifold feeds the turbo and all I had to do was tie into the down tube off the turbo with a 3" 90 degree stainless elbow. From the elbow I just welded the bombshell muffler onto the pipe. A lot of guys out west run the bombshell mufflers welded directly to the header collector. I have no idea what they sound like or how loud they are since I haven't fired mine yet but I'm betting they would be pretty loud off a straight header. My turbo should quiet it down some. Here is a link to there site: http://www.camcofab.com/index.html
Here is an older pic of my set-up:
PostPosted: Sun Feb 17, 2008 12:22 am
that thing looks mean. very nice!! maybe a x in the back part of the frame.
PostPosted: Sun Feb 17, 2008 7:52 pm
can you run open headers with a subie or will it hurt the motor
PostPosted: Sun Feb 17, 2008 8:56 pm
I don't think it would hurt as long as you have a decent length of tubing. You really need some backpressure but not much. The muffler I am using might as well be a straight header since its a straight through design with puched baffles around the inside.
PostPosted: Mon Feb 18, 2008 7:59 am
The need for back pressure is a myth.
PostPosted: Mon Feb 18, 2008 8:26 am
Hill Climber
It is? What about tubing size does that matter?
Harry S. Truman
PostPosted: Mon Feb 18, 2008 10:26 am
Tubing size does matter.
PostPosted: Mon Feb 18, 2008 2:20 pm
"The need for back pressure is a myth" Roy what are you basing this on. If pipe size matters then in effect you are changing the back pressure in the engine. The smaller the pipe the greater the pressure drop thru it hence the greater the back pressure. The larger pipe would cause the oppoite effect. It is my understanding in order to maintain torque in the low and midrange RPMs you need back pressure so that you dont lose part of your intake charge out the exhaust hence losing power in that range. At the upper RPM range back pressure is less significat due to the high scavenging effect and in actuallity you want less backpressure because you will lose power in that range. For the offroad buggy I would think more back pressure is in your favor. Granted the cam has a lot to due with how much back pressure is required. Food for thought.
PostPosted: Mon Feb 18, 2008 3:12 pm
Well it depends on alot of things and what you are trying to accomplish. All I said was that the NEED for back pressure is a myth. You do not NEED back pressure. The orig. question was about not running a muffler.
Changing the tubing size does not create back pressure nor does it take it away.
What you really WANT to do is create a vacuum in the exhaust. That's why most of us use a merged system. This is what creates scavaging (vacuum) in the exhaust. Far cry from pressure in the exhaust.
The tubing size you choose should be based on the displacement (cc's) of the engine. The length of these tubes will change where your motor makes torque in the RPM range.
PostPosted: Mon Feb 18, 2008 6:32 pm
In theory, an engine with no backpressure will have more torque and more horsepower. The real reason for a motor with smaller pipes making more torque is because of the scavenging effect of the exhaust pulse. As the exhaust pulse moves through the pipes it is actually pulling the exhaust from the cylinder as the exhaust valve opens. ( think of it as syphoning). Backpressure will do nothing but slow down the piston from coming up on the exhaust stroke. I build and tune motorcycle race engines and I know this to be true. However there is really no way to build an engine with zero backpressure unless it doesn't have an exhaust. And even at that, you won't have good torque cause of the loss of "syphon".
 Post subject: exhaust
PostPosted: Wed Feb 20, 2008 12:45 am
Hey fortydegnorth, where did you get the stainless 3 inch elbow and do they have other sizes as well? I'm in the process of installing a Dodge 2.2L turbo engine in my buggy. Right now it just has a 2 1/2 inch straight pipe about 3 feet long and bent to fit my buggy. I got it running and it doesn't sound so good.
PostPosted: Wed Feb 20, 2008 5:01 pm
www.jegs.com they have all different sizes and bends. Just about any speed shop would carry them.
PostPosted: Tue Mar 04, 2008 7:47 pm
hows the swap going steve ? post some picks
PostPosted: Tue Mar 04, 2008 7:56 pm
[quote='purplerail']hows the swap going steve ? post some picks[/quote]
I will gather pics and post asap. Its been goin slow due to knoched up sister in law.
PostPosted: Tue Mar 04, 2008 8:44 pm
[quote='Steve'][quote='purplerail']hows the swap going steve ? post some picks[/quote]
I will gather pics and post asap. Its been goin slow due to knoched up sister in law.[/quote]
Was the wife mad? LOL just kiddin
Bryan
PostPosted: Tue Mar 04, 2008 11:33 pm
ya Steve i think i'm going suby.want to see pics.
PostPosted: Sat Mar 15, 2008 3:11 pm
here's a couple of pics of my exhaust
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Mar 15, 2008 3:40 pm
aint that pretty
PostPosted: Sat Mar 15, 2008 8:30 pm
This is how I did mine
PostPosted: Sat Mar 15, 2008 11:22 pm
Heres how I did mine.
[img][img]http://i223.photobucket.com/albums/dd87/jem203/IMG_2575.jpg[/img]
Ok Dave designed it!![/img]
PostPosted: Sat Mar 15, 2008 11:28 pm
sweet .... whats it sound like?
PostPosted: Sat Mar 15, 2008 11:33 pm
Dont know, I'm starting on electrical system tomorrow. Hope to start it soon. I need to find a high torque starter to start it. Hope it sounds like a v-dub.
PostPosted: Sat Mar 15, 2008 11:50 pm
Lookin pretty sweet Steve cant wait to see
This one time at wellsville
