It is currently Mon May 04, 2026 9:51 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
 Post subject: tiking
PostPosted: Mon Feb 18, 2008 10:51 pm
my motor is ticking. its almost the same sound i had last winter. last winter i sherred the dial pins off my crank. but we checked it and my flywheel was tight. any idea on what i could be in trouble for? its just a stock motor and the only upgrade is a 2 barrel.
thanks guys,
dave
PostPosted: Mon Feb 18, 2008 10:59 pm
check the valves? adjust them see if it helps.
PostPosted: Mon Feb 18, 2008 11:06 pm
knock?
PostPosted: Mon Feb 18, 2008 11:09 pm
2 of my rockers are looseone i dont think is adjusted right but the one i can move it about a 1/4 side to side. i dont think thats normal. right?
PostPosted: Mon Feb 18, 2008 11:18 pm
do you run stock rockers? if so you probably broke spring washer. its the wavy one.
PostPosted: Mon Feb 18, 2008 11:23 pm
ya stock. it just seems to be the rocker. ill check in a sec and post
PostPosted: Mon Feb 18, 2008 11:26 pm
the spring n washer are fine. just i can move the rocker waayyyy to far. all my other ones are solid.
PostPosted: Mon Feb 18, 2008 11:35 pm
you have your rocker, on either side is a flat washer,then spring washer then flat washer.you should have a gap between flat washers where spring washer is.it could be cracked.i have had this happen to me a couple of times.
PostPosted: Mon Feb 18, 2008 11:38 pm
theres a huge fckin space on each side if the rocker
PostPosted: Mon Feb 18, 2008 11:42 pm
Did you break a clip?
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Mon Feb 18, 2008 11:46 pm
i dont know much about motors. can you explain
yea check your clips
PostPosted: Mon Feb 18, 2008 11:53 pm
clips?
PostPosted: Mon Feb 18, 2008 11:59 pm
i see the spring. on the rocker its not there on the loose one. i cant find it i hope its not in the motor
PostPosted: Tue Feb 19, 2008 12:46 am
was it in your valve cover?
PostPosted: Tue Feb 19, 2008 12:48 am
the clips slide over rocker shaft and hold your rocker w/washers in place.
PostPosted: Tue Feb 19, 2008 3:58 pm
no i didnt see anything in the valve covers. and my clip is there
PostPosted: Tue Feb 19, 2008 6:41 pm
have you recently had your rocker shafts off? maybe forgot to put in on.i dont think it would pass through your pushrod tubes.but you may want to ask somebody else if they have ever ran into this.
PostPosted: Tue Feb 19, 2008 7:49 pm
havent pulled them off. im going to pullthem off tonight when the garage heats up. its a bit chilly up in northern ohio. haha. it used to be my dads motor then the bastard upgraded. haah. but i work with what i got. i wanna put some 1.25 ratio rockers on. help any? make a diff? plz tell experiences. if its worth it or not
 Post subject: Busted Wavey washer
PostPosted: Tue Feb 19, 2008 8:26 pm
Here is a pic of a broken wavey washer from my 1915. Found it b-4 it went into oil pan.[img][img]http://i119.photobucket.com/albums/o157/silversandoffroad/IMG00024.jpg[/img] Image This pic shows a little of what the rockers and shafts look like. Thanks Dave T Image This last pic shows what happens to the non-hardened tips [/img]
PostPosted: Tue Feb 19, 2008 8:50 pm
1. id get me some big foot ball adjusters. thanks for the pics. were gonna pull it off tonight. ill post pics later
 Post subject: Re: Busted Wavey washer
PostPosted: Tue Feb 19, 2008 8:58 pm
[quote='dave t']Here is a pic of a broken wavey washer from my 1915. Found it b-4 it went into oil pan.[img][img]http://i119.photobucket.com/albums/o157/silversandoffroad/IMG00024.jpg[/img] Image This pic shows a little of what the rockers and shafts look like. Thanks Dave T [img]http://i119.photobucket.com/albums/o157/silversandoffroad/IMG0
PostPosted: Tue Feb 19, 2008 9:30 pm
I hada clip break on a rocker shaft once ---It sounded to me like a rod that kept coming and going.I had a buddy pull me back to trailer. Once i figured it out I done away w/ stock shafts -went HD bolted shafts. Good luck with your problem. Mark
Mark
High speed
Low drag
Teflon coated
PostPosted: Tue Feb 19, 2008 9:32 pm
thanks guys. i wouldnt be as far. yet alone have half as much knowledge as i do.
PostPosted: Wed Feb 20, 2008 3:14 pm
yeah i switched to 1.25 rockers for my 1641. i had pat at LA order me autocraft ones, they have bolt ends, no clip BS.
