It is currently Mon May 04, 2026 5:34 am
 Post subject: Tranny and engine tilt?
PostPosted: Mon Feb 18, 2008 8:27 am
I like that tilted engine look. I run suby and could use the added engine to ground clearance. I am redoing my rear tranny mount and wonder how much to raise the rear of the tranny. Yall give me some pointers please. :?
PostPosted: Mon Feb 18, 2008 10:30 am
You can tilt it as much as you want but you need to be careful you don't over do it. To high in the rear and your CV angles will start to get high. You might start binding them and need to reduce your ground clearance to compensate. Not a good thing.
R
PostPosted: Mon Feb 18, 2008 10:46 am
Do I tilt the front down some to keep the cv's in the same location?
PostPosted: Mon Feb 18, 2008 1:01 pm
[quote='Firebug']Do I tilt the front down some to keep the cv's in the same location?[/quote]
Thats what we do, just kinda rotate the tranny around the axis thru the center of the cv flanges...nose down a little (one nosecone bolt above the torsion, the other below) and bellhousing up a little.
PostPosted: Mon Feb 18, 2008 1:23 pm
We did Steve's like Larry said, tilted the front down and the rear up and it keeps the cv flange in close to where it originally was.
PostPosted: Mon Feb 18, 2008 6:41 pm
Dave and I put mine in with the front lowered about 1 1/2 and raised the rear 1 1/4. Then we mounted the engine by the suby not the bell. The bell bolts are just above the v-dub trans mount. I will go out and take some pics later.
