It is currently Mon May 04, 2026 11:38 am
 Post subject: need help
PostPosted: Mon Feb 11, 2008 7:44 pm
i was riding my 4 wheeler and the chain came off and the gard for the front sprocket got riped off and it was apart of the engin so now i have a small hole in the case where it happend but the piece that broke off will match back up good and cover th hole is there something i can use to seal it togeather so i wont leak oil :?:
PostPosted: Mon Feb 11, 2008 7:58 pm
Is the piece where its broken aluminum? If so, getting it welded would be the best choice, but...
If its not under stress or no weight hangs on it, believe it or not, JB Weld should hold for a long time. Clean the area first with electrical contact spray cleaner or brake parts spray cleaner. Give it at least overnight to dry.
PostPosted: Mon Feb 11, 2008 8:02 pm
yea its aluminum and there is no stress in the spot it broke i got some jb weld at the shop i will try that
PostPosted: Mon Feb 11, 2008 8:33 pm
we had a dirtbike that did something similar except it was on the clutch cover we jb welded that and rode it for yewars and it still held up to the day we sold it and a old friend of mine had a 98 xr 400 he never washed it the day he went to change the oil he went to back the drain bolt out and snapped a chunk of the case out we jb welded that also
PostPosted: Mon Feb 11, 2008 9:45 pm
jb weld of magnum steel. we put many back together with the stuff. always the chain breaking and slapping back into the case.
"Lets go get stupid"
PostPosted: Mon Feb 11, 2008 10:04 pm
I used JB Weld for a hole in the side of a case...
Clean it good ... NO Oil...
I used a piece of aluminum screen, because I was missing a piece the size of a quater, just roughed up area around the hole so that there was something for the JB weld to grip to.
I put a couple coats on.. Lasted a couple years, and it wasn't leaking when I sold it...
Good Stuff :D
I carry it in my tool box.
Lucky711
PostPosted: Mon Feb 11, 2008 10:27 pm
yeah jb weld will work good, used it on a few things. try to get the area roughed up pretty good like lucky said and get er clean. should do the trick.
PostPosted: Mon Feb 11, 2008 10:29 pm
ok thanks for the help will let u know what happens
PostPosted: Mon Feb 11, 2008 10:36 pm
i seen a stick go through an oil pan and get repaired with jb weld and a beer can patch good stuff right there!
PostPosted: Mon Feb 11, 2008 10:39 pm
haha sound good
PostPosted: Mon Feb 11, 2008 10:49 pm
If you want it tig welded, I can do that for you...
PostPosted: Tue Feb 12, 2008 11:09 am
This might work but its not as cheap as JBweld
http://durafix.com/demo/256.html
PostPosted: Tue Feb 12, 2008 11:24 am
that stuff is pretty cool brad
PostPosted: Wed Feb 13, 2008 9:34 am
[quote='JeffClay']that stuff is pretty cool brad[/quote]
Are you Jeff that rides at Walhonding with Paul?
PostPosted: Wed Feb 13, 2008 10:47 am
[quote='hillaholic']This might work but its not as cheap as JBweld
http://durafix.com/demo/256.html[/quote]
thats awesome!
Mike
Got Honda?
