It is currently Mon May 04, 2026 4:53 am
 Post subject: amount of tranny fluid??
PostPosted: Sun Feb 10, 2008 11:14 pm
How much fluid do you put in 091 6rib tranny??
PostPosted: Sun Feb 10, 2008 11:19 pm
I do believe it's around 4 quarts. When your filling it as soon as it starts to come out of the fill hole on the driver side, it's full.
PostPosted: Mon Feb 11, 2008 12:26 am
Thanks man..
PostPosted: Mon Feb 11, 2008 7:47 am
Like DVS1 said, I just filled my 002 3 rib and it was dry from the rebuild. It took 3 1/2 quarts, I think the 091 is a bit larger case so it will probably hold 4 or just a bit more.
The Wild Kids
PostPosted: Mon Feb 11, 2008 11:59 am
[quote='nickschlemer']How much fluid do you put in 091 6rib tranny??[/quote]
Like Dave said, fill it till it starts coming out the fill plug hole.
Wait 5-10 minutes and check it again.
It takes a bit for the fluid to pass through the bulkhead from the gearbox to the ring & pinion area and level out.
