It is currently Tue May 05, 2026 12:48 am
 Post subject: New pedals
PostPosted: Sat Feb 09, 2008 2:21 pm
Well i got my new pedals today. I was wondering if anyone had any suggestion or pics of there setup. Scince my pedals have reserviors on them do i not neeed to run a master cylinder also i have no idea how the lines hook in to my calipers theres little tits onn my brake caliper four on each caliper what do i do?? Also i have no idea how to hook up my clutch?? i bought a hydraulic clutch and slave cylinder i know where the slave cylinder goes and thats about it..Any suggestions, or pics of your setup will help me out. Also someone mention puttin a chain link in between your slave cylinder and arm anyone got a pic of this setup...Also i got a gas pedal to so suggestions on that to would be helpful. Sorry guys this is my first build so lots of questions about everything..
PostPosted: Sat Feb 09, 2008 2:52 pm
The resevoirs on your pedals are your master cylinders. Sounds like you are talking about the bleeders on your calipers. If they look like tiny hose barbs they are the bleaders. Between the bleeders there should be a threaded hole with a sticker over it or a plug in it, that is where the brake line goes in. If they are the porsche style calipers that come with most VW disc kits they are a metric thread. If the calipers are Wilwood or something similar they are likely a standard 1/8" NPT thread. NPT is "national pipe thread". NPT is a tapered thread getting smaller the deeper it goes into the part. The clutch essentially hooks up just like a brake line. Solid line from the clutch pedal master cylinder to the transmission. From there you must use a hose to connect the solid line to the slave cylinder, since it will have movement. The slave has a bleeder on it also just like the calipers. The pedals should all be mounted where they are comfortable to you. Always use a plate under the pedals that is attached to the frame. Attaching directly to an aluminum floor in my opinion is asking for trouble. Here is a pic of my pedal assembly from my last rail. I had hoses from the master cylinder to the hard lines because my pedals were adjustable.
Anywhere there is movement use a hose. From the frame to the calipers or from the frame to the rear trailing arms use hose. I like to use a short hose on my rear calipers also so I can remove the caliper to change pads without taking the hard line loose, a lesson I learned on the last one. If you have disc on the back use a 2# residual pressure valve, if you have drum use the 10#. Somewhere in the front lines should be a proportioning valve if you want to adjust the front brakes. If you have tailights don't forget the brake light switch. Plan ahead, draw everything out and have someone check it before you waiste a bunch of time and money.
PostPosted: Sat Feb 09, 2008 5:00 pm
Hill Climber
Here is I did. I like it.
Harry S. Truman
PostPosted: Sat Feb 09, 2008 5:16 pm
this mat help u
 Post subject: Gas
PostPosted: Sat Feb 09, 2008 10:17 pm
What about my gas pedal. I have the cnc gas pedal thats slanted with a foot rest. Should i use the cnc hydraulic set-up and does any one have a pic of this..
PostPosted: Sat Feb 09, 2008 10:52 pm
Hill Climber
I have the same pedal you have. Works good. I don't know anyone with hyd. throttle.
Harry S. Truman
PostPosted: Sat Feb 09, 2008 10:57 pm
Also what size brake line should i run?? Steel or stainless.
PostPosted: Sun Feb 10, 2008 12:11 am
I have never heard anything good about the hydraulic throttle. Most seem to use a morse style cable or just a steel cable run through a brake line or aluminum fuel line. 3/16" line is the most common for brakes. Steel or stainless is up to you. Brake fluid attracts moisture and more often than not a line will rust from the inside out. Plenty of people use standard steel line and it works fine. Stainless will be more money. My current build has the same angled pedal. On the pedal foot rest is a hole or series of holes that allow you to screw the ball end into for the cable to connect with.
PostPosted: Sun Feb 10, 2008 12:59 am
[quote='fortydegnorth']I have never heard anything good about the hydraulic throttle. Most seem to use a morse style cable or just a steel cable run through a brake line or aluminum fuel line. 3/16" line is the most common for brakes. Steel or stainless is up to you. Brake fluid attracts moisture and more often than not a line will rust from the inside out. Plenty of people use standard steel line and it works fine. Stainless will be more money. My current build has the same angled
PostPosted: Sun Feb 10, 2008 10:08 am
Read about them here:
http://www.glamisdunes.com/invision/ind ... c+throttle
 Post subject: Re: New pedals
PostPosted: Mon Feb 11, 2008 11:51 am
[quote='nickschlemer']Well i got my new pedals today. I was wondering if anyone had any suggestion or pics of there setup. Scince my pedals have reserviors on them do i not neeed to run a master cylinder also i have no idea how the lines hook in to my calipers theres little tits onn my brake caliper four on each caliper what do i do?? Also i have no idea how to hook up my clutch?? i bought a hydraulic clutch and slave cylinder i know where the slave cylinder goes and thats about it..Any sugges
PostPosted: Mon Feb 11, 2008 12:33 pm
I bought my pedals from mooreparts.com. I would have to say i think they just sell the parts and have no idea what their selling. There customer service is probably the worst ive dealt with. Although a lady there named elizabeth is pretty nice and helpful but has no idea about tech support.
