It is currently Mon May 04, 2026 3:01 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 08, 2008 9:20 am
Well i do a little of both hillclimbing and trail rideing plus i do have 1.5 ratio rockers in it and i have over sized valves so she can breath i just need to get in the woods and see how it does cause i dont want to do like everybody else i want to get up a hill they cant :eek:
Lets Ride!!!
 Post subject: valves
PostPosted: Fri Feb 08, 2008 4:31 pm
Also i have another question guys my heads have a bigger intake valves but stock exhaust valves will this help or hurt my torqe and is there a reason 4 doin that or do i need to get bigger exhaust valves or will it be ok like it is or is there a reason 4 the different valves ??????????? :? :? :? :?
Lets Ride!!!
PostPosted: Fri Feb 08, 2008 9:22 pm
Every engine combination needs something different to work well. There is no perfect choice. You have to decide "how you want it to perform" and choose the heads and camshaft based on your wants. I get my Crower stuff direct. Call them. I highly recommend the 61004 camshaft and it works even better with 1.25 rocker arms. If you have stock size exhaust valves this cam is your best choice.
 Post subject: crower61004
PostPosted: Sat Feb 09, 2008 2:20 pm
that was exatly the cam that was in the motor b4 but it had a bad lobe is the only reason i switched where and how much is the crower 61004 i think the motor was stronger with that cam!!!!!!!! :eek: :eek: it even sounded meaner and i have 1.5 rockers if you would give me the number or site thanks lots :D
Lets Ride!!!
PostPosted: Sat Feb 09, 2008 11:38 pm
I agree with Roy on getting another Crower Cam. Although Crower lists all of thier cams being compatable with 1.1/1.25/1.4 ratio rocker arms, I would use a 1.25. I feel a 61004 is better than an Engle 110. The VZ Cams are good, but have very sharp ramps to the lobes. If you are using a Mag. Case, it will wear your lifter bores out a lot quicker. You used to be able to get Crower Cams for around $75, but a couple of years ago they drastically raised thier prices. Jim's Custom VW's in Columbiana Ohio has Crower 61004's in stock, but now they're up to around $115 I think. IMO the extra $20-$40 you may have to pay for a Crower over most others is well worth it. I know many people that have run Crower Cams that like them, and they'll still buy them if they're $200. I'll be using a Crower 61005 in my new 2332. Give Jim's a call Monday at 1-800-621-3503 if you're interested in getting another Crower.
 Post subject: Cam Chart (Old!)
PostPosted: Sun Feb 10, 2008 10:16 am
http://www.actionimport.com/Tech_Files/cam_information.htm
PostPosted: Sun Feb 10, 2008 8:39 pm
I think that cam is awsome it seems a lot stronger than that scat i will check on the cam
Lets Ride!!!
PostPosted: Fri Feb 22, 2008 5:13 am
the guys i ride with use 100's in 1835's and 110's or c-35's in 1914's. but evey thing inside is stock crank rods and such so we like to keep the rpm's down. works great.
