It is currently Mon May 04, 2026 10:20 am
 Post subject: welding wire size
PostPosted: Wed Feb 06, 2008 7:04 pm
What is everyone using for wire? I have .035 right now using 75% / 25% gas. Im thinking about going to .030 wire when i run out of this.
PostPosted: Wed Feb 06, 2008 7:33 pm
.035 with the same argon co2 mixed gas.
PostPosted: Wed Feb 06, 2008 8:41 pm
i use rods
PostPosted: Wed Feb 06, 2008 9:11 pm
What size welder are you using? The 75/25 is the best gas to go with for most mig welding on mild steel and chromoly! The wire goes hand and hand with the size welder ----most don't have the larger amp welders [200 and up],run .030 and up. The smaller amp welders that usually run 110 volts run .022-.035 wire ----they don't have the amps to melt the wire and hold a constant duty cycle for the larger wires.
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Wed Feb 06, 2008 10:21 pm
I have the Lincoln SP175 and I started out with .025 that I found to be too small for anything thicker than .040". I went to .030 wire and it works on anything a throw it at. Now keep in mind I am a novice so my thoughts on this really mean squat lol.
PostPosted: Wed Feb 06, 2008 11:44 pm
I have used them all.. I also have a sp 175 Lincoln and I have ran 100 rolls through it. Main thing imo, is to keep a felt "wiper" on the wire. Anyway, I like .023(.025) or .030 the best. I can weld thicker stuff (buggy frame no problem) with the .023...
The 110 volt welders are very limited and have to be run at full output to weld a buggy frame and with a 30 amp breaker.
PostPosted: Thu Feb 07, 2008 8:28 am
I have a millermatic 250 so power is no problem it will run .045 dual shield if i want. I used to be a certified welder / fabricator and have used everything from .030 to 1/16th dual shield as well as tig and stick which i have 3 certs. in. I was just wondering what everyone was using for buggy frames. I have drive wheels and tips for .030 and .035 so switching over is not problem. Just not sure what I want to use on a new frame. and also I didn't find anything on welders or wire sizes on here so I figure its a thread we can compile info that someone may find on down the road.
PostPosted: Thu Feb 07, 2008 8:29 am
Eric good call on the "wiper". All of the welders i have used have those but do some not have them?
PostPosted: Thu Feb 07, 2008 10:13 am
All the race shops here use the same set up as mentioned above on mild and chrome ---75/25 w/ .030 !!!
Mark
High speed
Low drag
Teflon coated
PostPosted: Thu Feb 07, 2008 1:18 pm
I agree....it is the best setup to use the .030 wire and 75/25 gas mixture on a 110V welder, but I use a .035 wire on my 240V Lincoln 250 Mig welder.
PostPosted: Thu Feb 07, 2008 1:48 pm
Mine is 240V also. I am going to need wire soon so I figured now would be a good time to change. Never had any trouble with .035 but I have always liked .030 better for some reason. In the shop i used to work at we had machines set up for .030 solid core, .035 solid core, .035 dual shield, .045 dual shield, and 1/16th dual shield. Most of my work was done in the field with 7018 stick on 1/4" or better material and most of the shop work i did was with the 1/16th dual shield. Neither is practical for a buggy frame.
PostPosted: Thu Feb 07, 2008 2:14 pm
.030 is better than .035 for welding buggy tubing.
PostPosted: Thu Feb 07, 2008 2:57 pm
thats kind of what I was thinking.
PostPosted: Thu Feb 07, 2008 10:54 pm
[quote='Roy'].030 is better than .035 for welding buggy tubing.[/quote]
Yeah, I agree... it has a "finer" bead control, imo.
