It is currently Mon May 04, 2026 8:39 pm
 Post subject: Power steering again..
PostPosted: Thu Jan 31, 2008 3:45 am
Hey guys,
I cant seem to find shit on power steering for V.W.. Anyone got any pics or can someone explain to me better the exact setup. Do i run a power steering motor on my engine do i run a power rack. What do i do????
PostPosted: Thu Jan 31, 2008 6:09 am
Those that I know that have power steering run a pump off a belt on their motor. I have seen some homemade brackets to some well machined ones. Depends on what you want to do and pay for.
The Wild Kids
PostPosted: Thu Jan 31, 2008 7:00 am
Hill Climber
You can check this out.
http://www.howeperformance.com/
Harry S. Truman
PostPosted: Thu Jan 31, 2008 10:38 am
There are basically 2 setups you can use. The first and simplest is the Torque generater. It is mounted between the steering rod and the Rack and is the power assist. The pump mounts to the motor or frame and is driven off of a pully bolted to the crank in front of the alternater pully. (BTW I have a brand new pully I will not be using if your interested). The down side of the Torque generater is all of the load is on the rack. The second and better system is the Servo/Ram. The servo mounts in the same place the Torque generater would go. The ram is attached to the rack and the frame. This system works kinda like a hydraulic log splitter. But instead of useing a handel and a valve body to control the fluid flow to move the ram back and forth the servo does that for you. As you turn the wheel the servo directs the flwo to the corresponding end of the ram and pushs on the ram slider. Keep in mind that there is still a mechanical connection to the rack from the steering colume just like if you did not have power sterring. So if you lost a belt etc. You would still have sterring.
I bought most of the parts for mine on ebay at a fraction of the cost buying new. A completes system new is $1500.00 I have around $600.00 in mine.
PostPosted: Thu Jan 31, 2008 11:58 am
I had a servo ram system it sucked it is on a chaindrive I sold Jeff Busby he then sold it to Mickey mouse both will tell you . they both have the torque genarator now I have been running a torque gen for 8 years on the same rack .My wife has run one for about 6 or 7 years with a econo rack ain't broke yet and we don't baby them and a chain drive is a hole lot harder on a front end than a conv buggy
PostPosted: Thu Jan 31, 2008 1:48 pm
Ok would you care to elaberate on "It Sucked". What was it that you did not like about it?
PostPosted: Thu Jan 31, 2008 7:47 pm
IT was to slow unless you had it wide open it was not power at idle no power mine you can sit next to a tree with motor idleing turn wheel and move the buggy over with your pinky finger turning the wheel .And I said mine sucked I didnot say yours sucked I hope you like yours I sho do like mine
torque gen $328.57
saco rack $350
pump off a hundia $25
lines $50
around $753 bucks
sounds good to me
PostPosted: Thu Jan 31, 2008 7:59 pm
I think it depends on the pump and ram that are used. A lot of guys are running the servo ram setup on rockcrawlers that rarely rev above 2500 rpm's and turn 40"-50" tires standing still or against rocks. A ram with too large of a bore will be very slow. If you buy a ram buy one specifically made for your application not an off the shelf ram from tractor supply that is made for a log splitter. The torque generator is proven also for forklifts.
PostPosted: Thu Jan 31, 2008 9:52 pm
I have had to machine different size pulleys to increase or decrease the pressure at lower rpm's---just another thing to consider.
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Thu Jan 31, 2008 11:54 pm
rockrockets1, I know you did not say that mine sucked, I was just wondering what was it about yours that you did not like. I have not even used mine yet. Thats why I asked. I had considered that possiable problem at idel. I had purchased a pully and when it came it was only 3" diameter. Just be sure I had enough pump speed at low RPM I went with a 4" pully. I also used a Sweet ram that has a 1 1/4" Diameter piston to help with low speed driving.
PostPosted: Fri Feb 01, 2008 8:39 am
[quote='Odyknuck']rockrockets1, I know you did not say that mine sucked, I was just wondering what was it about yours that you did not like. I have not even used mine yet. Thats why I asked. I had considered that possiable problem at idel. I had ourchased a pully and when it came it was only 3" diameter. Just be sure I hade enough pump speed at low RPM I went with a 4" vpully. I also used a Sweet ram that has a 1 1/4" Diameter pistion to help with low speed driving.[/quote:48
PostPosted: Fri Feb 01, 2008 9:38 am
Eric the 4" pully is for the motor. The pully on the pump is 6". The 3" motor pully I had would be a 2:1 ratio. The 4" gives me a 1.5:1 ratio so the pump turns faster.
PostPosted: Fri Feb 01, 2008 12:46 pm
At idle but whay about 8800 rpm then that sucker is pumping air bubbles and foam
PostPosted: Fri Feb 01, 2008 1:43 pm
My motor will never see 8800 RPM. Even if it did the Pump would only see 5867 RPM and most pumps have a max of 6000 RPM. My cam is only going to allow the motor to turn at max 6000 RPM and the pump would see 4000 RPM. I would think that the average Motor RPM will be around 4000 so the average pump RPM would be at 2667. My recieving canister also has a defoaming baffle so that will help a lot. I think Im covered
PostPosted: Fri Feb 01, 2008 11:06 pm
[quote='Odyknuck']Eric the 4" pully is for the motor. The pully on the pump is 6". The 3" motor pully I had would be a 2:1 ratio. The 4" gives me a 1.5:1 ratio so the pump turns faster.[/quote]
My bad..sorry..
I wonder if you can turn one too fast? I have a grandam rack and it works great, but it (the pump) needs to be a little faster then idle, and I already have it turning a lot faster (smaller pulley on pump) then it was on the car. Maybe the car had a
PostPosted: Fri Feb 01, 2008 11:54 pm
Yes you can turn a pump to fast. I believe tha max is 6K in general before they start to cavitate. As you said Its possiable that your rack needs more volume that the pump is capable of providing. Basically a mismatch.
PostPosted: Sat Feb 02, 2008 10:59 am
Has anyone tried the electric pumps from the newer chevy cobalts? Sounds like a good idea if it works..
PostPosted: Sat Feb 02, 2008 3:15 pm
that system is a pain in the ass requires a p/s modual pcm and bcm to work
