It is currently Mon May 04, 2026 7:30 pm
 Post subject: What carb for 1641?
PostPosted: Tue Jan 29, 2008 7:16 pm
I currently run a solex 34pict. I can get weber progressive w/manifold for dirt cheap. Should I go with that or what? What do you guys suggest. Thanks Jason
PostPosted: Tue Jan 29, 2008 7:20 pm
2 barrel. you wont be let down. it idles, has a good midrange, and has that 2nd barrel thats lets it rip. i have the set up. 1641 and 2 barrel. great
PostPosted: Tue Jan 29, 2008 7:24 pm
webber 40 or 44 works great if jets are right
PostPosted: Tue Jan 29, 2008 7:26 pm
frankenbuggy06 what 2barrel do you run?
 Post subject: Re: What carb for 1641?
PostPosted: Tue Jan 29, 2008 8:21 pm
[quote='J.DiNapoli']I currently run a solex 34pict. I can get weber progressive w/manifold for dirt cheap. Should I go with that or what? What do you guys suggest. Thanks Jason[/quote]
Thats the only way I would buy one,If you can try and find a 40 or 44 weber you will be happier in the long run.I have a weber progessive I`ll give you just pay shipping no manifold though.
aaron
PostPosted: Tue Jan 29, 2008 8:27 pm
Are they no good?
PostPosted: Tue Jan 29, 2008 8:39 pm
motor craft or progressive. im guessing a progressvie
PostPosted: Tue Jan 29, 2008 9:18 pm
They are not the greatest,they are hard to jet because you have to take carb completely apart to change jets.And anything above a stock motor you wont get the performance you are looking for or could get out of 40 or 44`s.Here are pics of the one I have its yours for $15 or anybody that wants it.
aaron
For a 1641 a Weber progressive is a good choice in my opinion. I had one on a 1641 with 10:1 compression and a W-110 cam and 1.25 rockers that climbed everything I pointed it at. Jet it right and get the double squirter (accelerator pump jet) and you should be happy.
PostPosted: Tue Jan 29, 2008 9:38 pm
i have found that the webber 44 or 48's have all top end. i do not believe that it would give a good trail ride w/o loading up. but just my opinon. sorry if i offend anybody but i dont think its the right set up. i like the 2 barrel
PostPosted: Tue Jan 29, 2008 9:44 pm
i ran a 1641 3 rib with a prog it worked well but i put a 44 on it and it woke up night and day differance
PostPosted: Tue Jan 29, 2008 10:11 pm
was it all top end though? could you lug it and then just getinto it and it be right there?
PostPosted: Tue Jan 29, 2008 10:19 pm
no pretty good all over wit a 110 cam 31 inch tires but all buggys are diff if i could get a prog fo 100 or so i would run it but i would not buy a new one i would go with the 44 if buying new. i may have a prog intake
PostPosted: Tue Jan 29, 2008 10:45 pm
[quote='frankenbuggy06']i have found that the webber 44 or 48's have all top end. i do not believe that it would give a good trail ride w/o loading up. but just my opinon. sorry if i offend anybody but i dont think its the right set up. i like the 2 barrel[/quote]
If you jet them right they will lug all day long and then scream when ever you want it to.
PostPosted: Tue Jan 29, 2008 11:18 pm
i did not know that. im sorry for putting them down. my buddies couldnt get the jetting for it so they sold them after 3 rides in wellsville and about 12 in the yard
PostPosted: Tue Jan 29, 2008 11:25 pm
cb has alot of diff jets if the prog is cheap go for it use it till you outgrow then step up
PostPosted: Wed Jan 30, 2008 12:13 am
i run all stockother than a 110 cam 1641 with a dell 40 run great just had to play with jets to get it right. Dave
PostPosted: Wed Jan 30, 2008 12:19 am
[quote='frankenbuggy06']i did not know that. im sorry for putting them down. my buddies couldnt get the jetting for it so they sold them after 3 rides in wellsville and about 12 in the yard[/quote]
If you happen to get any get the weber tech manual and call cb performance and you will be able to get them dialed in.
aaron
ps. anybody want the progressive?
PostPosted: Wed Jan 30, 2008 1:53 pm
Hill Climber
From what I have seen the Weber progressive is great while it's working. If it gives you problems throw it away and buy a 44 Weber.
Harry S. Truman
PostPosted: Wed Jan 30, 2008 6:51 pm
I run a w110 cam,lightened flywheel,and mofoco 040 heads. Also 31" goodyear wrangler terras. How much for 40 or 44 webber?
PostPosted: Wed Jan 30, 2008 9:19 pm
[quote='J.DiNapoli']I run a w110 cam,lightened flywheel,and mofoco 040 heads. Also 31" goodyear wrangler terras. How much for 40 or 44 webber?[/quote]
with that set up you would be happier with a 40 or 44 weber or delloroto,I think new there close to $300 for weber or hpmx delloroto`s heven`t been made for 25 years but you can find them half price on ebay.
aaron
PostPosted: Wed Jan 30, 2008 9:41 pm
I have a stock fuel pump. Will that be in the way when putting weber progressive on? Any 2barrel for that matter?
PostPosted: Wed Jan 30, 2008 9:56 pm
fits just fine
PostPosted: Wed Jan 30, 2008 10:42 pm
[quote='dunebuggy79'][quote='J.DiNapoli']I run a w110 cam,lightened flywheel,and mofoco 040 heads. Also 31" goodyear wrangler terras. How much for 40 or 44 webber?[/quote]
aaron[/quote]
aaron, why would those carbs be better for my set up? Ja
PostPosted: Thu Jan 31, 2008 4:04 pm
no the pump wont be in the way at all
