It is currently Tue May 05, 2026 2:23 am
PostPosted: Sun Jan 27, 2008 9:29 pm
13 TO 1 2.5 LITER BIG VALVE HEAD FORD 4CYL ON PROPANE
(LIVE EVERY DAY LIKE IT IS YOUR LAST) AND AS I TELL MY 10 YEAR OLD BOY ANYTHING BROKEN CAN BE FIXED
PostPosted: Sun Jan 27, 2008 9:37 pm
Pinto, here is a link to a calculator that you put in all your engine info and it will give you a map that might help. Put in different AR rating numbers to get the best on a map.
The Wild Kids
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
opps double posting
Last edited by The Wild Kids on Mon Jan 28, 2008 12:18 pm, edited 1 time in total.
PostPosted: Sun Jan 27, 2008 10:11 pm
i have never ran turbo i do not understand the graph. is there a rule of thumb
PostPosted: Mon Jan 28, 2008 9:55 pm
although I have no experience on Pinto engines with turbos i do have vast experience with them on VW engines and if I was going to run one on a woods type engine I would try to keep it as close to 8.0 to 1 as possible.
PostPosted: Tue Jan 29, 2008 1:44 am
Sorry, I forgot I had posted on this thread. I apologize! Aaron is right you need to drop the compression way down if you are going to run a turbo. What type of a set up as far as carbs are you looking to run. What I mean is are you going to run a blow through or EFI? Since you are running LP gas I would guess either would work with only minor differences. I have another web site that I will try to locate that has a ton of turbo info. Also you might want to send TurboBlue a PM and ask his help. He is very knowledgeable on turbo's.
The Wild kids
PostPosted: Tue Jan 29, 2008 7:14 am
you can run 10 to 1 with a timing retarder with racing fuel. i'm doin it
PostPosted: Tue Jan 29, 2008 8:33 am
[quote='Aaron Creech']although I have no experience on Pinto engines with turbos i do have vast experience with them on VW engines and if I was going to run one on a woods type engine I would try to keep it as close to 8.0 to 1 as possible.[/quote]
Aaron is the man on VW turbo. He has one of the fastest drag bugs there is. Not to mention it looks good also.
PostPosted: Tue Jan 29, 2008 8:48 pm
Thanks Bruce.Have we met at a race somewhere?Maybe London.
PostPosted: Tue Jan 29, 2008 10:30 pm
[quote='Aaron Creech']Thanks Bruce.Have we met at a race somewhere?Maybe London.[/quote]
We met at the London drag way. I was with Chuck Jones. (Chuck told me you are one of the best there is on turbos) That is one fast and good looking bug you have.
PostPosted: Tue Jan 29, 2008 10:35 pm
Thanks alot,hope to see you again there this summer.
PostPosted: Tue Jan 29, 2008 11:38 pm
Thanks for the advice I got in touch with Racer Walsh today and theay said it would take a stock milled head with my valve train and springs to get where it needs to be along with a turbo cam and pistons.theay also said for the best results the compression needs to be around 8 to1.Sorry for the trouble but I have to much money tid up in compression to throw it away.But I will find another project to put the propane and turbo on. Theay also told me that there wasn't going to be any gain running propane over racing gas as far as HP for know I am going to run the Mikunis backed with pro nos foggers. THANKS FOR ALL THE IN PUT
PostPosted: Wed Jan 30, 2008 10:26 am
there is a big diffrence propane is 174 gal race fuel is 550
PostPosted: Wed Jan 30, 2008 10:31 am
[quote='rockrockets1']there is a big diffrence propane is 174 gal race fuel is 550[/quote]
But if you have a buggy and your having fun what does it matter what the price of the gas is??
PostPosted: Wed Jan 30, 2008 10:35 am
he is talking about turbo power so why wast the extra 376 :?:
PostPosted: Wed Jan 30, 2008 10:45 am
thats wright why not :?: it's like a cold bud light on a hot summer day it just goes down so good
PostPosted: Wed Jan 30, 2008 6:35 pm
It is a lot easier to bolt a holly base with mixer to a 2 barrel intake than to tune all 4 carbs. And I have a cage full of propane tanks 16 to be exact so propane is a lot cheaper for me to run but what about performance is 1 425 going to feed that little beast with out a turbo v/s 4 44mm carbs on racing gas. It is hard to put a price on performance.
