It is currently Mon May 04, 2026 10:34 pm
 Post subject: Intakes
PostPosted: Thu Jan 24, 2008 11:01 am
On my last ride I broke a intake. Bolt backed out on oneside and it snapped. Someone was kind enough to give a set of intakes but these are smaller than the ones I am running now. I have a 2276 with dual dell 40's. How will that effect performance with air flow restriction? Will I have to sync the carbs again if I use them?
Any help would be greatly appreciated.
Jason
PostPosted: Thu Jan 24, 2008 11:07 am
It will most likely hurt your performance. How much?????? You can open them up with a die grinder but you want to make sure they are both close to the same.
PostPosted: Thu Jan 24, 2008 11:17 am
Thanks Bruce
what about resyncing the carbs?
 Post subject: intakes
PostPosted: Thu Jan 24, 2008 11:27 pm
u probaly want ever notice any performance drop that u can notice,u shouldnt have to touch them dellortos maybe set the idle air setting a little thats it,if iy where webers it would be a different story,
