It is currently Sun May 03, 2026 4:36 pm
PostPosted: Mon Feb 06, 2017 5:08 pm
SOLD SOLD
For Sale or Trade: Will trade to Tires/Wheel and air cooled motor
350 Small Block Chevy, 010 4 Bolt main block, Standard Steel Crank, .030 Over Bore, 5.7 Steel Rods, Dish Pistons,
Heads: These are casting 492 heads that were setup and machined by Mike Bullock Race Engines in Somerset, KY, They have .208 Intakes, all valves are Stainless steel, The heads have screw in guide plates and 3/8’” screw in studs. Double Springs. I have the spring setup to run a roller for this set of heads also.
Performer Aluminum Intake
HEI Ignition
Double Roller Timing chain set
Holly 750 Carb
Newly rebuilt Power Guide 2 speed Transmission with 3000 Stall
This motor and transmission is new and has been started up and ran about 10 minutes.
Call or text Steve at 859-979-2438
PostPosted: Tue Feb 07, 2017 3:40 pm
Just put all this in a rail
