It is currently Sun May 03, 2026 4:03 am
 Post subject: Front beam wide
PostPosted: Sun Jan 22, 2017 8:22 pm
I don't know how wide to make my front beam I am running 1x4 trailing Arms in the front t
 Post subject: Re: Front beam wide
PostPosted: Sun Jan 22, 2017 8:44 pm
Most people run a 6 inch wider beam.
I have never understood the benefit of a 6 inch wider beam. If you are running taller tires, I guess it could help with the tire rubbing on the frame. Maybe you get a little more stability.
PostPosted: Sun Jan 22, 2017 8:48 pm
They track better in the high speed trails. I have +6 with 1x4 arms
PostPosted: Sun Jan 22, 2017 10:22 pm
I know +6 is normal but I run 2x3 rear and don't want my front to be to wide and I have 1x4 tweeds
PostPosted: Sun Jan 22, 2017 11:09 pm
I asked Nick Mailloux the same question. The answer was it gives better/more travel. Something about the geometry of the width.
PostPosted: Sun Jan 22, 2017 11:25 pm
My front is 76"
PostPosted: Mon Jan 23, 2017 7:58 pm
How would a wider beam give better/more travel? :?: :?:
PostPosted: Mon Jan 23, 2017 11:28 pm
I have no idea.:o
PostPosted: Mon Jan 23, 2017 11:30 pm
I know a longer vehicle rides smoother than a short one. So maybe a wider one does also.????
PostPosted: Tue Jan 24, 2017 1:48 pm
I run a 6" wider beam mainly to clear 31" front tires (no rub when turning) also helps with stability in off camber situations but it sucks in tight woods
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
