It is currently Sun May 03, 2026 11:14 pm
 Post subject: Rebuild (Cush53)
PostPosted: Fri Mar 11, 2016 10:11 pm
I figured it was time for an update on what I been up to. So to remind everyone I had a bad roll in the summer of 2014 and been working on it off and on since. But it is finally starting to get some progress
Sent from my XT1080 using Tapatalk
 Post subject: Re: Rebuild (Cush53)
PostPosted: Fri Mar 11, 2016 10:15 pm
PostPosted: Fri Mar 11, 2016 10:18 pm
PostPosted: Fri Mar 11, 2016 10:22 pm
PostPosted: Fri Mar 11, 2016 10:26 pm
Lots of new parts complete madmike front end beam, 3" drop spindles and 4x1 arms, new pedals, suspension seats, .120 Dom roof, rear hubs and rotors, all new steering including a power steering box, dragon fire 5 point harnesses. More to come shortly
PostPosted: Sat Mar 12, 2016 12:23 am
Looking good.
PostPosted: Sun Mar 13, 2016 3:19 pm
Looks good
PostPosted: Mon Mar 14, 2016 7:59 am
nice work
PostPosted: Mon Mar 14, 2016 6:10 pm
Thanks, its been awesome to finally get back to work on it.
PostPosted: Mon Mar 14, 2016 10:39 pm
Nice job on the rebuild! How are you doing the rear rotors? Did you cut the center out of the rotor? And Studs are going to hold the hub&rotor together? Just curious, I'm wanting to do something Like that. The splines in my rotor's are wore already.
PostPosted: Tue Mar 15, 2016 6:57 am
Those are VW drums cut down to fit inside Porsche 914 rotors, I will be putting thread in studs in them. It's a much stronger setup than the China made one piece rotors
PostPosted: Tue Mar 15, 2016 7:06 am
I was able to cut the center of the drums out with a porta band so the would fit in my small lathe to finish cutting to fit. You can find those rotors made by Zimmerman still Check out this item I found on eBay: http://pages.ebay.com/motors/link/?nav= ... 96&alt=web
PostPosted: Wed Mar 16, 2016 10:20 pm
Definitely stronger than the china rotors. Thank you for the info.
PostPosted: Fri Mar 18, 2016 9:19 pm
Yea it's looking good
PostPosted: Sat Apr 02, 2016 8:28 pm
Beautiful rise from the ashes. I need to redo my cage like yours. Helmet constantly hits it.
PostPosted: Sat Apr 02, 2016 11:48 pm
Thanks, got a little more done, it feels like I have got alot done but nothing is finished.
PostPosted: Sun Apr 03, 2016 2:37 pm
Looking good.
PostPosted: Wed Apr 13, 2016 6:58 am
PostPosted: Fri Apr 15, 2016 6:21 pm
Those old German VW drums were very strong. More like a forging. Nice to see your giving yourself plenty of head room. I need to do that to my rail. If you want E brakes use Audi A4 or Passat rear brake calipers. They are cable operated and the cable is on top so it won't get snagged. I would use press in studs. Sway Away makes longer 14 mm ones.
PostPosted: Sun Apr 17, 2016 3:09 am
PostPosted: Tue Apr 19, 2016 12:21 am
PostPosted: Wed Apr 20, 2016 6:57 am
