It is currently Sun May 03, 2026 12:44 am
 Post subject: Trans Jig
PostPosted: Tue Jan 26, 2016 9:45 pm
Can I use an 091 case as a jig to set set up my 002?
 Post subject: Re: Trans Jig
PostPosted: Tue Jan 26, 2016 11:44 pm
Yes
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Tue Jan 26, 2016 11:53 pm
Thanks
PostPosted: Wed Jan 27, 2016 8:53 am
no
PostPosted: Wed Jan 27, 2016 10:06 am
Hmm. Thanks
PostPosted: Wed Jan 27, 2016 11:46 am
3 and 5 rib can share a jig but 091 is just for 091.
PostPosted: Wed Jan 27, 2016 3:17 pm
Ok. I just found out its a 3 rib jig I'm getting and that's what I have is a 3 rib.
PostPosted: Wed Jan 27, 2016 6:50 pm
Then how do you run 002 gears in an 091 case? I know you can't do it the other way around but I know guys that run 002 gear set in a 6 Rib 8)
PostPosted: Mon Feb 01, 2016 10:34 am
I dont think I is the gears. I know the reverse idler is different. Its been years since I screwed around with either. I know I ended up throwing all my homemade jigs in the fire and used a "plate" style jig. I worked much much better and you had to use spacers for an 091 leading me to believe the mail shaft and pinion shaft are longer.
PostPosted: Thu Feb 11, 2016 6:38 pm
The main case from either will work for a jig, but you would have to use the reverse idler shaft from the 3 rib to hold the reverse idler gear.
