It is currently Sun May 03, 2026 6:48 pm
 Post subject: My new to me buggy
PostPosted: Mon Apr 27, 2015 8:28 pm
Went searching for a 4 seater so would have something for the kids to price around in.
Anyways, ended up buying a 4 seater Beeline Cobra (I think). Has a 3 rib, believe the motor is stock, with a weber progressive carb. Looks front heavy, but it actually isn't.
Last pic is in Racefreak J77's garage for alittle maintenance and a couple upgrades.
Went to adjust the torsion Sunday, and upon pulling off the trailing arms, discovered the drivers side was cracked from one side to the other. Good thing I had a set....
 Post subject: Re: My new to me buggy
PostPosted: Mon Apr 27, 2015 8:57 pm
Nice . I will be looking for it at lbl
PostPosted: Mon Apr 27, 2015 9:31 pm
It'll be there Memorial weekend. Gonna be there?
PostPosted: Mon Apr 27, 2015 9:44 pm
Planning on it .
PostPosted: Tue Apr 28, 2015 1:54 pm
WB Competitor
looking forward to seeing yall chris and damn i love messing with these things.
PostPosted: Tue Apr 28, 2015 7:37 pm
Maybe someone on here can provide some insight. Took the rear suspension apart to replace the arms. The drivers side stub axle will not come out of the spindle/hub. Make a long story short, while using a big press, the spindle/hub broke. Now I need to find another, but have no clue what it might have come off of. It is just a spindle with the splines on the inside, and the wheel studs. No drum or rotor. The rotor is a slip on, similar to most cars. Any thoughts on what to look for?
PostPosted: Tue Apr 28, 2015 8:06 pm
The most common setup that I know of is type 3 hubs turned down a bit to fit Porsche 914 rotors. That being said, my buggy had some other slip on rotor when I bought it.
PostPosted: Tue Apr 28, 2015 8:08 pm
After looking at your picture, I'm sure that you have the 914 rotors.
PostPosted: Tue Apr 28, 2015 10:10 pm
I am looking for a pair of rims like what you have on the front of your buggy, any ideas on where I might find some ?
PostPosted: Tue Apr 28, 2015 10:11 pm
Summit racing on rims
PostPosted: Wed Apr 29, 2015 4:16 pm
I know Appletreeauto.com has them as well.
