It is currently Mon May 04, 2026 6:54 am
PostPosted: Sun Jan 20, 2008 6:57 pm
What is the most HP/CC's this transaxle will take power wise without upgrading it?
Thanks, Bruce
 Post subject: tranny
PostPosted: Sun Jan 20, 2008 7:23 pm
me jus 2 be safe,no more than 150
PostPosted: Sun Jan 20, 2008 7:30 pm
I would say Chris is about right BUT it also depends on what tires you have and what clutch you are using.
PostPosted: Sun Jan 20, 2008 11:45 pm
unless your luck is like mine i'll break a 6 rib with a 36 horse
PostPosted: Mon Jan 21, 2008 7:50 am
I hear ya on that one. I can destroy a 6 rib with a 1641 and the wrong clutch installed.
 Post subject: clutch
PostPosted: Mon Jan 21, 2008 8:19 am
what kinda clutch you recomend roy?
PostPosted: Mon Jan 21, 2008 9:51 am
That depends on the weight of the buggy, what tires you are using, are the tires cut?, and the type of riding you will be doing. Any pavement riding involved? Dirt only? Any drag racing?
Not only is the clutch disc important but the pressure plate clamping force has to be considered as well. That will be chosen based on the weight of the car. It's hard to recommend something because everyone has their own opinions and experiences. Driving style has alot to do with it too. Will you be side stepping the clutch at 7 grand?
There is no perfect answer.........
The shock load on the gear teeth in the transaxle is transfered by the clutch. I am a firm believer to go conservative on the clutch. It's much cheaper to replace than a transaxle!
PostPosted: Mon Jan 21, 2008 12:24 pm
[quote='GAMNTRAIL']What is the most HP/CC's this transaxle will take power wise without upgrading it?
Thanks, Bruce[/quote]
Which vanagon?
There are two different versions.
For the most part they are the same as an 091.
The water cooled version has a much stronger reverse gear.
Got some guys running 2498cc engines on the w/c version and have been for 3 years.
PostPosted: Mon Jan 21, 2008 4:03 pm
Gary, what are the R7 Ps in the side shifts. I have heard thatbthe A/C units were 456s and the W/Cs were 486s.
PostPosted: Mon Jan 21, 2008 5:37 pm
[quote='turboblue'][quote='GAMNTRAIL']What is the most HP/CC's this transaxle will take power wise without upgrading it?
Which vanagon?
Got some guys running 2498cc engines on the w/c version and have been for 3 years.[/quote]
The vanagon was A/C it had the type 4 ....2.0 liter,
Thanks for
PostPosted: Tue Jan 22, 2008 6:36 pm
[quote='Odyknuck']Gary, what are the R7 Ps in the side shifts. I have heard thatbthe A/C units were 456s and the W/Cs were 486s.[/quote]
Well we popped the bell housing off a w/c tranny today.
34/7 was the tooth count, 4.857 is the ratio.
PostPosted: Tue Jan 22, 2008 10:29 pm
Well That confirms what I was told on the water cooled. Its about half way between the 3 rib and a nose shift 6 Rib. I think Im gonna like that. Not to tall not to short.
PostPosted: Wed Jan 23, 2008 11:11 am
That is the same as a 5-rib R&P.
PostPosted: Wed Jan 23, 2008 11:58 am
Any body ran both the 5 and 6 ribs that can share there experience with them. I have only ran the 3 rib and I felt it was geared with to high of a ratio.
PostPosted: Wed Jan 23, 2008 8:16 pm
You will LOVE the 4.86 ratio. There are times I wish my gearbox had one.
