It is currently Sun May 03, 2026 2:14 pm
 Post subject: VW Clutch Advice
PostPosted: Thu Apr 02, 2015 9:43 am
I have a question that I'm hopin the experts on here can help me with. I don't post on here very often but I do read every day, gotta have something to do at work. I have a basically stock 1600 in my buggy, single 2 barrel 40mm carb, car trans (I know), 2X3 arms, and 31" Swampers. My clutch is beginning to slip and I assume needs replaced. I have put more than one stock vw clutch disc in, and was wondering what the next step up would be? I ride mostly trails, but enough cold drinks will make me point it up hill. Nothing near as crazy as some of yall though. I don't have the funds to go all out just yet, but was curious as to what advice I might get. Thanks!
 Post subject: Re: VW Clutch Advice
PostPosted: Thu Apr 02, 2015 9:46 am
I ran a diakin clutch with a stage one pressure plate. worked great for me when I had the same set up as you.
PostPosted: Thu Apr 02, 2015 9:56 am
Probably need to change the pressure plate out to a Kennedy stage 1. I run a kush-lock clutch.
PostPosted: Thu Apr 02, 2015 11:41 am
Check the depth of your flywheel friction face (where the clutch goes).
Make sure that it has not been resurfaced to too low
of a depth. Also make sure that the throwout is working perfectly.
If the throwout is hanging up, you will see rapid clutch wear.
PostPosted: Thu Apr 02, 2015 12:03 pm
X2
PostPosted: Fri Apr 03, 2015 7:05 pm
Low on money,use same pressure plate and a 4 puck disk.
