It is currently Sun May 03, 2026 5:39 pm
 Post subject: Custom torsion problems
PostPosted: Sat Mar 28, 2015 8:49 am
How would I go about fixing the camber in my trailing arms. Passenger side is cambered quite a bit. Driver side not so bad but the distance between my swing plate to trailing arm is closer on the driver than the passenger. I can't even bolt up the swing plate.
PostPosted: Sat Mar 28, 2015 9:37 am
Sounds like the arms are distorted/ bent. Are they stock arms?
Even with reinforcing, stock arms can twist or bend. I twisted
a brand new pair of reinforced stock arms in one season.
Of course ...I do drive like a complete idiot.
PostPosted: Sat Mar 28, 2015 10:16 am
X2. Sounds like it's bent.
PostPosted: Sat Mar 28, 2015 1:20 pm
Are the trailing arms stock? I have seen people accidentally mount tube style trailing arms upside down.. that can create a problem with alignment
PostPosted: Sat Mar 28, 2015 8:17 pm
No the arms are good. They are mad mike 3x3s. They were fine on a stock torsion. I got a new frame with a custom torsion and I think the trailing arm pivots are off some.
PostPosted: Sat Mar 28, 2015 9:53 pm
Hows about a couple of pictures of the inboard pivot clips.
PostPosted: Sat Mar 28, 2015 9:54 pm
I change my opinion... Those arms being MadMikes I seriously doubt they are bent. I have seen pivots bent, crack and torn off.
PostPosted: Sat Mar 28, 2015 10:11 pm
Don't mean to high jack but, how can you set your arms ? Do you need axles and joints in or without them. I was doing to pull them to the same spot on spring plates and go from there. Or is there a simpler way?
PostPosted: Sat Mar 28, 2015 10:15 pm
You need to have the axles and cv's in to set your limits. I tell everyone to run a string line under the car centering it off the torsion housings. Measure everything from that string line.
PostPosted: Sat Mar 28, 2015 10:59 pm
Thanks mike, from front of buggy to center of torsion housing, then to something behind buggy. ?? Measure off that string to each side towards flange? If so that makes sense. Just like squaring anything else
PostPosted: Sat Mar 28, 2015 11:27 pm
As long as the string runs don the center of the car. You can set the toe on the front end and the toe on the rear arms so your car doesn't crab down the trail.
You can use a piece of extruded aluminum box tube about 36" long. Simply bolt it to the bearing housing and measure to it without a wheel/tire assembly.
PostPosted: Sat Mar 28, 2015 11:30 pm
Gotcha thanks
PostPosted: Sat Mar 28, 2015 11:56 pm
I will use the string method to straighten my rear arms out.
PostPosted: Sun Mar 29, 2015 6:21 am
1) Camber: Stock VW mounting of trailing arms is not actually trailing, but is more "semi-trailing". That being said, you can only
properly check for neutral camber when the spring plate is resting
(or just above) the lower stop. The wheel should be straight up and down.
2) Rear Toe: In order to get the proper thrust angle, the rear
wheels must be set so that they are parallel to one another. This means that in most cases their centerlines will NOT be exactly the same distances from the torsion housing centerline. Also, try to get both toe settings to parallel the centerline of the car chassis.
3) Thrust angle: If the front wheels are set to neutral toe, then the front common centerline axis should be parallel to the rear common centerline axis in order to achieve a neutral thrust angle.
PostPosted: Mon Apr 06, 2015 11:11 pm
MadMike thanks for string line trick. Worked great and I figured out that everything was right. Thanks
