It is currently Mon May 04, 2026 8:11 am
 Post subject: 3x3 Arms and back angle
PostPosted: Thu Mar 19, 2015 2:47 am
Just installed 3x3 arms on my buggy. Im running type 1 CV joints on the outside ( stub side ) What is the easiest way to figure out my back angle on the axle? I have an angle finder app on my phone but Im not sure its rite when I lay the phone on its side.
PostPosted: Thu Mar 19, 2015 8:02 am
its only 1 angle. you should be fine on back angle as long as your trans is in the stock location.
PostPosted: Thu Mar 19, 2015 11:57 am
another simple way to check it is make sure your axle has plunge through out the entire cycle. most importantly when your axle is level and when your tire is off the ground. as long as it doesn't get tight (look for 1/4" of plunge) you should be just fine.
